quadracerx
Mar 27 2015, 10:41 PM
Ive heard differing opinions on whether to sandblast a transaxle...
Some say it dangerous because of the magnesium case?
Some say it will leave a very rough surface?
I called the guys who do most of my sandblasting and they say the can bake most of the grease off then blast it with lower pressure... So it should be ok?
Your thoughts?
Thanks,
Steve
McMark
Mar 27 2015, 11:53 PM
Media blasting grit is magical. It will, no matter what you do, get into every passage, nook and cranny. You take a risk by using media on it. You can clean it well enough, but you must be completely thorough. Or use soda, which is water soluble.
Also note, the bare magnesium will corrode/oxidize. It should be coated with something to protect it.
Mar 28 2015, 12:54 AM
QUOTE(quadracerx @ Mar 27 2015, 09:41 PM)
Is it ok to sandblast a trasaxle?
No
VaccaRabite
Mar 28 2015, 06:51 AM
I'd only blast it if the trans were completely taken apart and the plan was to clean it 100% inside and out afterwards.
You are better off with degreaser and a scraper and stiff brush.
Zach
rgalla9146
Mar 28 2015, 07:31 AM
NO!
a few loose screws
Mar 28 2015, 07:48 AM
Just out of curiosity,can you use walnut, plastic or soda to blast the case? I know you don't want anything to embed in the case and start a reaction. Is it more about not removing the outer material, i.e. coating, or treatments from the factory?
