Rough Start after recent service, thoughts? |
914Next |
Mar 28 2015, 08:07 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Last week I had my '73 2.0 serviced by a well regarded air-cooled guy here in atlanta. Since the car is new to me I decided to do an oil change and have him do a valve adjustment also since I don't know when was done last.
In the end he changed oil, adjusted valves, put new valve cover gaskets on and replaced the spark plugs (as I recall replaced Bosch with NGK plugs). When I picked up the car at the garage it started and ran fine. The next day I drove it twice however and when cold it started fine. But when I was running a couple of errands the car sat for 20-45 minutes and when I went to re-start the car it seemed to be getting gas but stumbled and died immediately when I released the key. After 2-3 attempts, in both instances I could get it started and it seemed to run fine when started. Any idea what the culprit might be? It's disappointing since the car ran so well before the service and of course it's a bit unnerving not knowing it I'll be able to coax the thing to start when I'm out and about. I only have the one day experience with this problem. I'll try it again next week and see if it persists. Thanks |
TheCabinetmaker |
Mar 28 2015, 08:21 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That's how a leaking injector will react. The system can hold fuel pressure for half an hour after you turn it off. A leaky injector will flood one cylinder with gas. Next time it does it, hold gas pedal to floor till it starts.
Also, it could be the cold start valve stuck open. Remove the air filter box, open the throttle and look into the plenum for gas. The head temp sender (ts2) is also a suspect. Did the mech set the gap on the new plugs? They come gapped to about 34 thousandths. Should be 27. Hope this helps. |
914Next |
Mar 28 2015, 09:22 AM
That's how a leaking injector will react. The system can hold fuel pressure for half an hour after you turn it off. A leaky injector will flood one cylinder with gas. Next time it does it, hold gas pedal to floor till it starts. Also, it could be the cold start valve stuck open. Remove the air filter box, open the throttle and look into the plenum for gas. The head temp sender (ts2) is also a suspect. Did the mech set the gap on the new plugs? They come gapped to about 34 thousandths. Should be 27. Hope this helps. Thanks, I'll start by asking him if he set the gaps and we'll go from there,. |
Tom_T |
Mar 31 2015, 10:40 PM
Just take it back to him Steve, & ask him to trouble shoot it, since you paid good money for the service. If he's reputable & truly knowledgeable, then he'll find it & fix it for you.
If it's who I think you're talking about, then he'll make it right. If another, then also hopefully so. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
914Next |
Apr 1 2015, 06:24 AM
Thanks, Tom. I know he will.
Lo-Fi Version | Time is now: 4th May 2024 - 01:49 AM |
