Last week I had my '73 2.0 serviced by a well regarded air-cooled guy here in atlanta. Since the car is new to me I decided to do an oil change and have him do a valve adjustment also since I don't know when was done last.
In the end he changed oil, adjusted valves, put new valve cover gaskets on and replaced the spark plugs (as I recall replaced Bosch with NGK plugs).
When I picked up the car at the garage it started and ran fine. The next day I drove it twice however and when cold it started fine. But when I was running a couple of errands the car sat for 20-45 minutes and when I went to re-start the car it seemed to be getting gas but stumbled and died immediately when I released the key. After 2-3 attempts, in both instances I could get it started and it seemed to run fine when started. Any idea what the culprit might be? It's disappointing since the car ran so well before the service and of course it's a bit unnerving not knowing it I'll be able to coax the thing to start when I'm out and about.
I only have the one day experience with this problem. I'll try it again next week and see if it persists.
Thanks
