Is it OK to move car without rear stub axles? |
michael7810 |
Mar 28 2015, 09:23 AM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Just wondering. I need to move the car about 100 yards back int the garage to install the engine/trans/axles.
tomrev |
Mar 28 2015, 09:25 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Yes, just take care; as you know, the bearings are now loose, so take your time.
SLITS |
Mar 28 2015, 09:44 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Install axles first or you will have a hell of time putting them in with the drivetrain installed.
So, you might as well install them to support the bearing while rolling the chassis. |
Mike Bellis |
Mar 28 2015, 10:10 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Is it the axle and CV's removed or have you removed the stub as well? If the stub is in there and the axle nut is tight, roll it where ever you want. If the stub it out, be very careful.
Cap'n Krusty |
Mar 28 2015, 10:40 AM
Careful-shmareful! DON'T do it. A safe alternative would to be to get a long bolt and a couple of large washers to compress the bearing/hub assembly. Personally, I would just put the stub axles back in and torque 'em down.
The Cap'n |
michael7810 |
Mar 28 2015, 12:40 PM
Thanks for the info. I was trying to avoid remove the stubs from the CVs and dealing with the mess, gaskets, etc. but is sounds like a small price to pay for not screwing up something else. I'll mount the stubs before moving the car.
My Haynes shows 31 lb ft on the CVs and 217-253 on the stub axle nut. Does that sound right? Thanks again |
Andyrew |
Mar 28 2015, 01:53 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Ya, that sounds right. I generally put a 4 foot extension on my breaker bar and tighten it like its a lug nut.
Lo-Fi Version | Time is now: 2nd May 2024 - 05:02 PM |
