Upholstry shop used staples too long |
914ltd |
Mar 28 2015, 04:46 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Door panels are too thin for shops "short" staples. Anyone know a source for original length staples? Thanks, Brad
partwerks |
Mar 28 2015, 07:07 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Brad,
Do you have a picture of the staples you are referring to? |
scotty b |
Mar 28 2015, 07:24 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
vinyl basketweave wraps around the edges of the door panels and they are stapled to the fiber panel, around the edges on the backside
914ltd |
Mar 28 2015, 09:12 PM
The tips of the staples went all the way thru the fiberboard and created a lot of little lumps where the barbs went thru. These staples were the shortest the shop had. I measured the total height of an original staple and it is only 4mm.
rangrbob |
Mar 28 2015, 10:55 PM
Member Group: Members Posts: 170 Joined: 11-October 12 From: Loveland, CO Member No.: 15,027 Region Association: Rocky Mountains |
The tips of the staples went all the way thru the fiberboard and created a lot of little lumps where the barbs went thru. These staples were the shortest the shop had. I measured the total height of an original staple and it is only 4mm. Brad you'll need to find a source for 5/32" 22 gauge staples. Similar to the ones in the link below. The hardest part may be finding a gun that will shoot them. I used one that says the minimum length is 1/4", but it worked fine. http://www.stapleheadquarters.com/Categori...aspx?Id=Senco_C I can get you the info on the staples and gun I used in a couple days if you want. Karl |
TheCabinetmaker |
Mar 29 2015, 07:39 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I agree with Karl. 5/32" is only .001 less that 4mm. A cheap Hitachi staple gun should handle those.
BarberDave |
Mar 29 2015, 07:54 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
BRAD : The upholster used the wrong staples, seems to my it's his job to correct the error. Dave AKA BARBERDAVE |
914ltd |
Apr 8 2015, 08:11 PM
Thanks all. I am now correctly stapled. 5/32 is the answer. Brad
KELTY360 |
Apr 8 2015, 11:35 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
nomore9one4 |
Apr 9 2015, 07:35 AM
Member of the Eastcoast Thread Killers Club Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None |
5/32" and shoot the staple in at a slight angle! (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 03:00 AM |
