planning my new 914 garage |
siverson |
Mar 28 2015, 09:41 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
We bought a new house many months ago, and the house needed a ton of work. The "house" part of our remodel is almost over, and now I'm making plans for the garage. I actually can't believe I haven't but more thought into this yet as one of the primary reasons we (or I (IMG:style_emoticons/default/smile.gif) ) liked the house is it has a big 2-car garage AND a big 3-car garage. And a big yard. Yay me.
Without benches or storage, I think 10 914s would actually fit in the 2 garages (tandem). So... What do you think of my layout plan? Any other ideas below. The most space I've had to work with before this was a 22x20 2-car garage. 1. LIFT - We have to do some concrete work in the garage now anyways, so I think I may put some type of scissor lift in the floor. The ceiling is flat and only about 8.5' or 9.0'. - Any lift recommendations? - What needs to be plumbed into the lift? Just power or ? (I'm just starting my research now) - Do you think the center position is the best for the lift? 2. BENCHES. What do you think? Benches as I drew along the top, or benches in the bottom stall? That closet has to stay there. Any ideas or inspiration? Thanks! -Steve Attached thumbnail(s) |
rhodyguy |
Mar 29 2015, 12:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
No entry door other than the bay doors? The 16x7 notated in the wall on the left is what? Also, what is the compass direction that wall faces? Bear in mind any conflict with overhead door tracks. You might post some photos of the interior.
Greg smith equipment sells a 10' 2 post that might work for you with a couple of smallish holes in the ceiling for the extra post height to slip into. Looking at the side elevation, the exterior wall of the room above the garage is supported by the posts. Clear spanning the space will involve major engineering and surgery |
somd914 |
Mar 29 2015, 01:28 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Looking at the side elevation, the exterior wall of the room above the garage is supported by the posts. Clear spanning the space will involve major engineering and surgery Oops, lost track that this is an existing house, so yes, if those are posts it's not an easy change at this point... |
Lo-Fi Version | Time is now: 13th May 2024 - 10:38 AM |
