planning my new 914 garage |
siverson |
Mar 28 2015, 09:41 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
We bought a new house many months ago, and the house needed a ton of work. The "house" part of our remodel is almost over, and now I'm making plans for the garage. I actually can't believe I haven't but more thought into this yet as one of the primary reasons we (or I (IMG:style_emoticons/default/smile.gif) ) liked the house is it has a big 2-car garage AND a big 3-car garage. And a big yard. Yay me.
Without benches or storage, I think 10 914s would actually fit in the 2 garages (tandem). So... What do you think of my layout plan? Any other ideas below. The most space I've had to work with before this was a 22x20 2-car garage. 1. LIFT - We have to do some concrete work in the garage now anyways, so I think I may put some type of scissor lift in the floor. The ceiling is flat and only about 8.5' or 9.0'. - Any lift recommendations? - What needs to be plumbed into the lift? Just power or ? (I'm just starting my research now) - Do you think the center position is the best for the lift? 2. BENCHES. What do you think? Benches as I drew along the top, or benches in the bottom stall? That closet has to stay there. Any ideas or inspiration? Thanks! -Steve Attached thumbnail(s) |
GaroldShaffer |
Mar 29 2015, 08:20 PM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have a midrise lift and works great for dropping engines since I to do not have a enough height for a two post lift. I have a SCCA buddy that has the Maxjack system and that seems to work well also. I would add for you shelves on along the wall in 3 door garage shown next to the 914 (parked at a angle) I would use some heavy duty closet racking and hang it off the wall above the care so you can park straight. Use that area for storage of parts / stuff that you will not need access to that often. I did that in my garage and it helps keep stuff off the floor .
Lo-Fi Version | Time is now: 13th May 2024 - 04:47 AM |
