Arrived a few weeks ago, At Rodd Point NSW from Oceanside CA |
Downunderman |
Mar 29 2015, 11:54 AM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Its been a long process, but its here. The basis for a new historic racer. Its a 72 with a 2l with webers and side shifter. The motor will have to come back to about 1.8. Strangely, I can run either injection or carbs. It seems that when the 914 was originally homologated for historic racing nobody knew much.
I need a few parts, rear boot floor, rockers, front and rear valences, 2l injection - runners, throttle body and plenum, air cleaner, brain. Otherwise its better than expected. I will start pulling it apart over Easter. The plan is to send it out and get it dipped and see what comes back. Cheers, Attached thumbnail(s) |
Dave_Darling |
Mar 30 2015, 08:55 AM
LE air dam was an option for 74+ cars. Not sure if that would allow you to run it, though.
I'd suggest sticking with the carbs for a race car. They should be easier to set up than the D-jet, plus you already have them. Plus, if you're allowed to change the cam, you can get significantly more power with carbs than the D-jet. --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 09:08 AM |
