fuel filter qustion |
rosenfe |
Mar 29 2015, 06:11 PM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on a car with carbs do i need the metal cnnister fuel filter,or can i use an inline plastic see through filter?does the metal cannister filter need more pressure to work correctly as it was really meant to be used with fi.
914Sixer |
Mar 29 2015, 07:09 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Plastic in line with work fine with carbs since they only run 3-5 psi.
euro911 |
Mar 29 2015, 07:28 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I run a metal can filter in front of the pump mounted under the fuel tank, and another filter in the engine compartment. Due to the high temperatures in the engine compartment, I would recommend a metal with a glass sight tube.
Lo-Fi Version | Time is now: 28th April 2024 - 09:37 PM |
