butt head, butt weld.., I need some help |
TravisNeff |
Feb 14 2005, 02:09 PM
Hey all,
I have been trying to patch up A/C holes in my tub and having a helluva time blowing holes in the metal and voids around the weld area. I start with tacks in the corners and start tacking around the world in an offset pattern, when I have about 12 tacks in a circle I try to join the tacs. However when I tac, I most always blow a hole in the new sheet metal, or in the old panel. I have the worst time in the vertical position. I have ground down both sides of the panel (and patch) to clean metal. If I am not blowing a hole, only about 50% of the weld gets good penetration, when I hit it a little longer I blow a hole. I have even used a sorta chill bar to back the joint (1" copper pipe squished flat with a bend, suggested by another lister). Also, I am making most of my holes just buzzing a tack, not so much once I have an arc established. I have a Millermatic 175, using .023 wire and Argon/CO2 (about 24lbs pressure when I hit the switch), Guide states I should use #2 on voltage and 50 on the wire feed speed. I have no problems welding lap joints at these settings and it sounds like bacon frying when it does it, so I know I am close. I have gone down to 1.5 on voltage and reduced the wire feed to 40, still no luck. I have expanded my stickout (experimenting with 1" plus down to the 3/8's I normally do). The welds suck. Once I get done and grind the welds down smooth I almost always find a crack/void where the metal joins the weld. Weld, grind, weld grind. I can eventually get it right, fixing each one of the patches once I grind it down. I have tried the butt weld clamps, but the gap is huge, I can get the metal to almost (or actually touch) and hold it in with a magnet. What am I missing? Should I be using metal ready to clean the metal even further, try another technique? I am holding the gun at an upward angle and a touch over to the side (hell I have tried just about everything). |
TravisNeff |
Feb 14 2005, 10:39 PM
If I go down to 1 or even 1.5 I can see the arc strike and the wire burns up to the nozzle, wire feeds and burns up, so slow I can see and hear it buzz, fizzle, buzz fizzle. I will try the circular motion, same amperage range 1.5-2 and just turn down my wire speed. Again, I am getting blowouts once the arc strikes, when an arc is established and there is no blow out - no problemo' When filling those holes, I shoot at an angle at the corner of the hole, generally blowing yet another hole. Once I get it filled I got a big ole booger of weld to grind down and the penetration is flakey, where you can see voids/seams where each of the welds layer each other.
Thanks all, these are some great ideas. I'll let you know how I progress. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:29 AM |
