butt head, butt weld.., I need some help |
TravisNeff |
Feb 14 2005, 02:09 PM
Hey all,
I have been trying to patch up A/C holes in my tub and having a helluva time blowing holes in the metal and voids around the weld area. I start with tacks in the corners and start tacking around the world in an offset pattern, when I have about 12 tacks in a circle I try to join the tacs. However when I tac, I most always blow a hole in the new sheet metal, or in the old panel. I have the worst time in the vertical position. I have ground down both sides of the panel (and patch) to clean metal. If I am not blowing a hole, only about 50% of the weld gets good penetration, when I hit it a little longer I blow a hole. I have even used a sorta chill bar to back the joint (1" copper pipe squished flat with a bend, suggested by another lister). Also, I am making most of my holes just buzzing a tack, not so much once I have an arc established. I have a Millermatic 175, using .023 wire and Argon/CO2 (about 24lbs pressure when I hit the switch), Guide states I should use #2 on voltage and 50 on the wire feed speed. I have no problems welding lap joints at these settings and it sounds like bacon frying when it does it, so I know I am close. I have gone down to 1.5 on voltage and reduced the wire feed to 40, still no luck. I have expanded my stickout (experimenting with 1" plus down to the 3/8's I normally do). The welds suck. Once I get done and grind the welds down smooth I almost always find a crack/void where the metal joins the weld. Weld, grind, weld grind. I can eventually get it right, fixing each one of the patches once I grind it down. I have tried the butt weld clamps, but the gap is huge, I can get the metal to almost (or actually touch) and hold it in with a magnet. What am I missing? Should I be using metal ready to clean the metal even further, try another technique? I am holding the gun at an upward angle and a touch over to the side (hell I have tried just about everything). |
TravisNeff |
Feb 16 2005, 10:39 AM
Ok, so I went down to 1, then .5 on voltage and kept the wire speed up to about 40, ran some butt weld coupons in the vertical position, and doing cirlces.
That all helped well, if I blew a hold Perry's idea of a 3" stickout, hit the hole and move in quick (to normal stickout length) works great. Penetration got better but not good enough, either slowing way down helped but deposition on the top side increased. Just trying to get the hang of it I was back at the #2 on voltage and 50 on wire feed. Just when I was getting some good runs I ran outta gas.. Damn, I just had that filled 2 weeks ago - last tank did 6X the welding and lasted 3 times longer. Must have gotten a partial filled tank or somethin' |
Lo-Fi Version | Time is now: 17th May 2024 - 06:42 AM |
