butt head, butt weld.., I need some help |
TravisNeff |
Feb 14 2005, 02:09 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Hey all,
I have been trying to patch up A/C holes in my tub and having a helluva time blowing holes in the metal and voids around the weld area. I start with tacks in the corners and start tacking around the world in an offset pattern, when I have about 12 tacks in a circle I try to join the tacs. However when I tac, I most always blow a hole in the new sheet metal, or in the old panel. I have the worst time in the vertical position. I have ground down both sides of the panel (and patch) to clean metal. If I am not blowing a hole, only about 50% of the weld gets good penetration, when I hit it a little longer I blow a hole. I have even used a sorta chill bar to back the joint (1" copper pipe squished flat with a bend, suggested by another lister). Also, I am making most of my holes just buzzing a tack, not so much once I have an arc established. I have a Millermatic 175, using .023 wire and Argon/CO2 (about 24lbs pressure when I hit the switch), Guide states I should use #2 on voltage and 50 on the wire feed speed. I have no problems welding lap joints at these settings and it sounds like bacon frying when it does it, so I know I am close. I have gone down to 1.5 on voltage and reduced the wire feed to 40, still no luck. I have expanded my stickout (experimenting with 1" plus down to the 3/8's I normally do). The welds suck. Once I get done and grind the welds down smooth I almost always find a crack/void where the metal joins the weld. Weld, grind, weld grind. I can eventually get it right, fixing each one of the patches once I grind it down. I have tried the butt weld clamps, but the gap is huge, I can get the metal to almost (or actually touch) and hold it in with a magnet. What am I missing? Should I be using metal ready to clean the metal even further, try another technique? I am holding the gun at an upward angle and a touch over to the side (hell I have tried just about everything). |
Trekkor |
Feb 17 2005, 10:22 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I'm back in... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Before I go any further, know this: I am not judging or critisizing anyone. Nor am I upset or flaming ( definately not flaming ) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) People need to know it's o.k. to do things their way, too.
As far as concerns about moisture damage go, what about the fiberglass installs? ( all lapped ) I'm not hearing too much ( read any ) complaints about fenders falling off. Back to steel...The three really nice flare jobs here in the Bay Area I've seen are all lapped. They look great and you cannot tell unless you feel under there or look. I try not to do that...
Guessing? Hmm (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) John I saw your video, don't get me wrong. You are a master. The work you do is amazing and inspiring. Are you working the inside of the panels to hide evidence of body work, too? That would be insane. ( in a good way )
There are many ways to approach every project. Budget and time usually influence us I wasn't willing to spend another 10-20 hours in the battery area just so I could say "look, butt welds". A non cosmetic area should be a non-issue. Taking longer doesn't always mean better. Just longer.
Job specific, yes. People using factory tested methods as a base for their restorations and replicas, weak?, not a chance. Be careful when you perk up the ears of the majority of the car buffs out there. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I will use whatever methods I deem neccesary to complete my projects. I not a know it all. More of a don't know much at all (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Thanks to all for the help and advice. And for threads like this. KT (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:37 AM |
