Armchair Diagnosis? |
914Next |
Mar 31 2015, 01:31 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
As mentioned a few days ago, my previously superbly running 2.0 now has a hot starting problem. I had my mechanic change the oil, do a valve adjustment since I didn't know when that had last been done by the PO. He also put in new plugs. Car started fine when I picked it up but the next day I drove it and when I tried to start after running it, it stumbled and would not start. I'll call him today to see what he thinks.
Based on my limited experience with this new problem…. It seems to start when cold. If started immediately after running it tends to start fine. If the car sits for 10-15 minutes or more after running it does what you see in the video. So, while I was trying to video my new Triad exhaust the car hesitated to start again. Not sure if this video helps any of you with ideas on what my problem might be thought thought it couldn't hurt. https://youtu.be/SC87ukKDebE |
pilothyer |
Mar 31 2015, 02:51 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I would first check the CHT Sensor............PM Sent.........................Jerry
pilothyer |
Mar 31 2015, 03:13 PM
PM sent with Phone number
Mar 31 2015, 05:59 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yup, CHT
These motors get hotter when shut off. It's a heat sync thing that fades away eventually. You need to do a simple ohm test on the CHt. |
skjl47 |
Mar 31 2015, 10:34 PM
Newbie Group: Members Posts: 21 Joined: 2-June 13 From: Northeast TN Member No.: 15,957 Region Association: None |
Hello; I once had a similar problem of a 914 stalling when hot. I traced it back to having replaced the stock fuel filter with a metal one.
The heat from the engine/exaust would sink into the metal fuel filter especially when stuck in traffic. I imagine the fuel was boiling inside the metal filter. The engine would start after sitting a while. Problem went away with a factory fuel filter in place. Good luck |
Lo-Fi Version | Time is now: 26th April 2024 - 12:27 PM |
