Armchair Diagnosis? |
914Next |
Mar 31 2015, 01:31 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
As mentioned a few days ago, my previously superbly running 2.0 now has a hot starting problem. I had my mechanic change the oil, do a valve adjustment since I didn't know when that had last been done by the PO. He also put in new plugs. Car started fine when I picked it up but the next day I drove it and when I tried to start after running it, it stumbled and would not start. I'll call him today to see what he thinks.
Based on my limited experience with this new problem…. It seems to start when cold. If started immediately after running it tends to start fine. If the car sits for 10-15 minutes or more after running it does what you see in the video. So, while I was trying to video my new Triad exhaust the car hesitated to start again. Not sure if this video helps any of you with ideas on what my problem might be thought thought it couldn't hurt. https://youtu.be/SC87ukKDebE |
r_towle |
Mar 31 2015, 05:59 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yup, CHT
These motors get hotter when shut off. It's a heat sync thing that fades away eventually. You need to do a simple ohm test on the CHt. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:34 AM |
