AKA- Wreck 2015 route 66- Fix is done! Picks page 12, Thanks to everyone for all the help! Couldn't have done it without you |
JRust |
Mar 31 2015, 01:58 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so anyone who was following the Route 66 thread. Know I got stuck in a rain storm. Coming around a corner just outside of Oakridge. I hit standing water on the road. Car spun & I ended up sliding into the guard rail on the opposite side of the road backwords. Absolutely sucked but I was very lucky nobody was coming the other way. Could have been so much worse. I wasn't hurt in any way other than my pride. Seeing my car damage after only having it back a month from my fire. I have no words to explain it other than it Fuching sucks (IMG:style_emoticons/default/headbang.gif)
So moving on here are pics of the carnage the day of. There is also 2 creases/dents in my front flare. The extra chassis stiffening helped a lot. The brace from the front of the suspension ear. To my firewall I think kept the damage from being much worse. The way my rear wheel caught the guard rail lip pressed directly on that brace I believe. Because of this the trailing arm buckled. I am glad that I did not do the trailing arm reinforcement. I have heard conflicting things on it. I know see why in my opinion it shouldn't be done. If your trailing arm bends it is much better than your car bending or breaking. Trailing arms are pretty easy to replace. Ripped suspension ear or other frame damage not so much. I'll add pics of my car on the rack today in the next post Attached thumbnail(s) |
JRust |
Apr 12 2015, 08:24 PM
Didn't get much time this weekend to do much to my car. I did make a trip up to Camp914 to pick up a pair of Replica 8x16 Fuchs. On the way back hit Harbor freight to buy a new port-a-power. Had one a while ago but it died (IMG:style_emoticons/default/sad.gif) . I also picked up my new used trailing arm from my buddy Brent. Dave sent me the trailing arm with a reinforcement plate on it. Wasn't quite finished by the PO so Brent offered to finish it off for me. Thanks bud
So tonight I spent a little while with a wire wheel & some sandpaper. Put a prime coat on & let it dry. Added another coat of prime & let it dry. Did a little sanding with some 150 grit. Sprayed on some black & it's out drying now. Left it under a light to help dry. Going to go flip it over in an hour to spray the other side. Then it will sit overnight. I'll add another coat tomorrow after work. |
76-914 |
Apr 22 2015, 08:51 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Didn't get much time this weekend to do much to my car. I did make a trip up to Camp914 to pick up a pair of Replica 8x16 Fuchs. On the way back hit Harbor freight to buy a new port-a-power. Had one a while ago but it died (IMG:style_emoticons/default/sad.gif) . I also picked up my new used trailing arm from my buddy Brent. Dave sent me the trailing arm with a reinforcement plate on it. Wasn't quite finished by the PO so Brent offered to finish it off for me. Thanks bud So tonight I spent a little while with a wire wheel & some sandpaper. Put a prime coat on & let it dry. Added another coat of prime & let it dry. Did a little sanding with some 150 grit. Sprayed on some black & it's out drying now. Left it under a light to help dry. Going to go flip it over in an hour to spray the other side. Then it will sit overnight. I'll add another coat tomorrow after work. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 07:33 PM |
