AKA- Wreck 2015 route 66- Fix is done! Picks page 12, Thanks to everyone for all the help! Couldn't have done it without you |
montoya 73 2.0 |
Apr 7 2015, 03:05 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Haha! you didn't move!!!
Chris914n6 |
Apr 7 2015, 03:09 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
That's a RoadGlue Pic. I believe he left the shutter open. Why am i the only one who isn't ghostyfied? (IMG:style_emoticons/default/blink.gif) Camo finding lens technology. |
sixnotfour |
Apr 7 2015, 03:44 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
LOL! Nice you found those Jeff! Man was Elliot pissed I held up the drive. Guess it's my fault he skips the drive portion now (IMG:style_emoticons/default/sad.gif) . Oh the same of it (IMG:style_emoticons/default/wacko.gif) On the second day drive I waited for him on a right turn...He drove right on by.... (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Apr 7 2015, 08:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That's a RoadGlue Pic. I believe he left the shutter open. Why am i the only one who isn't ghostyfied? (IMG:style_emoticons/default/blink.gif) I thought you'd be jealous! (IMG:style_emoticons/default/poke.gif) That pic looks like one of your Masterpiece's, Andy. (IMG:style_emoticons/default/av-943.gif) |
JRust |
Apr 9 2015, 07:44 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Up in the lift seems litke my passenger door does have a little larger door gap (IMG:style_emoticons/default/sad.gif) . Either way at WCR I will find out for sure if I need a Cellete pull after all. Think I will be towing it down just in case. Then if I need to drop it at Original Customs. I still have a way home (IMG:style_emoticons/default/evilgrin.gif)
JRust |
Apr 12 2015, 08:24 PM
Didn't get much time this weekend to do much to my car. I did make a trip up to Camp914 to pick up a pair of Replica 8x16 Fuchs. On the way back hit Harbor freight to buy a new port-a-power. Had one a while ago but it died (IMG:style_emoticons/default/sad.gif) . I also picked up my new used trailing arm from my buddy Brent. Dave sent me the trailing arm with a reinforcement plate on it. Wasn't quite finished by the PO so Brent offered to finish it off for me. Thanks bud
So tonight I spent a little while with a wire wheel & some sandpaper. Put a prime coat on & let it dry. Added another coat of prime & let it dry. Did a little sanding with some 150 grit. Sprayed on some black & it's out drying now. Left it under a light to help dry. Going to go flip it over in an hour to spray the other side. Then it will sit overnight. I'll add another coat tomorrow after work. |
Mike Bellis |
Apr 12 2015, 09:56 PM
You're running out of time... tick, tock...
WCR is 16 days away... (IMG:style_emoticons/default/drunk.gif) |
JRust |
Apr 13 2015, 08:30 PM
You're running out of time... tick, tock... WCR is 16 days away... (IMG:style_emoticons/default/drunk.gif) Yes I know! I've got to get on the ball. Besides the trailing arm I need to put my front strut's back together. Swapping to 3.5" caliper finally. Been waiting to do it. Just need to put it all back together. Plan to put them together tomorrow night. Then back on the car thursday night. |
VegasRacer |
Apr 14 2015, 09:06 PM
ELVIRA Group: Benefactors Posts: 8,502 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
This is only half a hijack. (IMG:style_emoticons/default/hijacked.gif) I wanted to keep all the carnage together.
Jamie was not the only one to damage their 914 on the way to Palm Springs for the Rt 66 Classic. My transmission started making some unhappy noises on the way to the event. Mine is also now being repaired for the upcoming West Coast Classic. Transmission out. Transmission apart. This bearing could be the problem. The ring and pinion also show some damage. One of the plates is scorched from being overheated. |
Elliot Cannon |
Apr 14 2015, 09:15 PM
LOL! Nice you found those Jeff! Man was Elliot pissed I held up the drive. Guess it's my fault he skips the drive portion now (IMG:style_emoticons/default/sad.gif) . Oh the same of it (IMG:style_emoticons/default/wacko.gif) Me? Pissed? Naaaah! Not possible. (IMG:style_emoticons/default/smoke.gif) |
rick 918-S |
Apr 14 2015, 09:36 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
This is only half a hijack. (IMG:style_emoticons/default/hijacked.gif) I wanted to keep all the carnage together. Jamie was not the only one to damage their 914 on the way to Palm Springs for the Rt 66 Classic. My transmission started making some unhappy noises on the way to the event. Mine is also now being repaired for the upcoming West Coast Classic. Transmission out. Transmission apart. This bearing could be the problem. The ring and pinion also show some damage. One of the plates is scorched from being overheated. Crunchy! (IMG:style_emoticons/default/unsure.gif) |
JRust |
Apr 14 2015, 09:43 PM
Yowser John (IMG:style_emoticons/default/sad.gif) . Glad you made it back home without more problems. See you in 2 weeks bud. At least you can slum it (IMG:style_emoticons/default/lol-2.gif) in the Cayman if it isn't ready (IMG:style_emoticons/default/confused24.gif)
VegasRacer |
Apr 21 2015, 10:07 PM
Elvira is out of surgery and will be ready to go after a good bath. (IMG:style_emoticons/default/boldblue.gif)
Andyrew |
Apr 21 2015, 10:31 PM
Jamie, If you need any help from me at WCR I'd be glad to help! Ricks a better bodyman than me by a longshot so I wont stand in the way of that. (IMG:style_emoticons/default/smile.gif)
brant |
Apr 21 2015, 10:46 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Elvira is out of surgery and will be ready to go after a good bath. (IMG:style_emoticons/default/boldblue.gif) Cool |
76-914 |
Apr 22 2015, 08:51 AM
Didn't get much time this weekend to do much to my car. I did make a trip up to Camp914 to pick up a pair of Replica 8x16 Fuchs. On the way back hit Harbor freight to buy a new port-a-power. Had one a while ago but it died (IMG:style_emoticons/default/sad.gif) . I also picked up my new used trailing arm from my buddy Brent. Dave sent me the trailing arm with a reinforcement plate on it. Wasn't quite finished by the PO so Brent offered to finish it off for me. Thanks bud So tonight I spent a little while with a wire wheel & some sandpaper. Put a prime coat on & let it dry. Added another coat of prime & let it dry. Did a little sanding with some 150 grit. Sprayed on some black & it's out drying now. Left it under a light to help dry. Going to go flip it over in an hour to spray the other side. Then it will sit overnight. I'll add another coat tomorrow after work. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
McMark |
Apr 22 2015, 09:43 AM
Waiting for a replacement roller bearing for the one that was dinged up. Should be here today and everything on its way to Jamie today. (IMG:style_emoticons/default/boldblue.gif)
rick 918-S |
Apr 22 2015, 11:38 AM
Packing a few of my favorite tools to ship to McMark tonight. (IMG:style_emoticons/default/smash.gif)
tdgray |
Apr 22 2015, 01:51 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
That is totally cool of you guys... well done brothers... well done (IMG:style_emoticons/default/smile.gif)
JRust |
Apr 22 2015, 04:39 PM
Yeah the 914 community is the best! I've got parts coming in this week galore. Kinda last minute but what would WCR be like without the last minute fixes. I'll get some pics up as I did get that back corner pushed back close to the right place. Still not perfect by any means. I think it is still destined for some shop time & a Cellete (IMG:style_emoticons/default/sad.gif) . My door gap on the passenger side is a little bigger (IMG:style_emoticons/default/sad.gif) . I do have it on the lift but with the longitude stiffening kit on it. It shouldn't flex I wouldn't think with the top on. I'll do what I can do for now. Then makes some decisions after Rick & all the guys smarter than me get a look (IMG:style_emoticons/default/evilgrin.gif) .
Lo-Fi Version | Time is now: 6th May 2024 - 03:37 PM |
