Wiring Harness Snorkel, Got your attention.... |
Series9 |
Mar 31 2015, 02:39 PM
As most of these are in bad condition, how are you concours guys handling this?
Attached thumbnail(s) |
JmuRiz |
Mar 31 2015, 02:49 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Not sure how the 914rubber ones compare to stock/concours ones, but I know he makes them.
JeffBowlsby |
Mar 31 2015, 02:50 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
914rubber and lots of KY or Glycerin.
Series9 |
Mar 31 2015, 03:42 PM
I didn't realize Mike made those. That's what we'll do.
falcor75 |
Mar 31 2015, 11:21 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I bought one from Mike but the upper flange that goes thru the engine shelf seems to be too small? or is the hole in my shelf too large? It doesnt seem to be tampered with in any way?
ConeDodger |
Mar 31 2015, 11:32 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I bought one from Mike but the upper flange that goes thru the engine shelf seems to be too small? or is the hole in my shelf too large? It doesnt seem to be tampered with in any way? You're in Sweden Mats... (IMG:style_emoticons/default/poke.gif) the hole probably shrunk from the cold last winter??? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/lol-2.gif) |
euro911 |
Apr 1 2015, 12:39 AM
1. It's Mark ('Mikey914' is Mark's son's member name and he never posts anything).
2. I've read a few posts where some folks have had to cut the new snorkel (to shorten it) overlap and glue back together after pulling the harness through. I haven't got that far into he restoration to know if I'll need to do that or not (IMG:style_emoticons/default/confused24.gif) |
falcor75 |
Apr 1 2015, 04:33 AM
I bought one from Mike but the upper flange that goes thru the engine shelf seems to be too small? or is the hole in my shelf too large? It doesnt seem to be tampered with in any way? You're in Sweden Mats... (IMG:style_emoticons/default/poke.gif) the hole probably shrunk from the cold last winter??? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/lol-2.gif) Yes my snorkel always shrinks in the cold... (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Apr 1 2015, 09:32 AM
Another one of the minor differences between early and late cars. I can't remember exactly which is which now or when the changeover is, but there is a difference.
euro911 |
Apr 1 2015, 01:33 PM
(IMG:style_emoticons/default/WTF.gif) … how'd this happen? (duplicate of post # 7) (IMG:style_emoticons/default/confused24.gif)
Mikey914 |
Apr 1 2015, 06:42 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I made the snorkel from the 75 car my son had, and I don't own any early ones. Never dreamed the hole and harness would change, why would it be necessary, more tooling and expense?
I did make them slightly longer to accommodate 6 conversions, but the 1" can be easily taken up but making the ornamentation35 deg off and bowing it out. Yes they can be cut and overlapped if you want too. |
falcor75 |
Apr 1 2015, 11:30 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427952627.1.jpg)
I think I'll just make a piece of aluminium with the correct sized hole and glue it to the underside of the shelf.... |
ConeDodger |
Apr 1 2015, 11:49 PM
I bought one from Mike but the upper flange that goes thru the engine shelf seems to be too small? or is the hole in my shelf too large? It doesnt seem to be tampered with in any way? You're in Sweden Mats... (IMG:style_emoticons/default/poke.gif) the hole probably shrunk from the cold last winter??? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/lol-2.gif) Yes my snorkel always shrinks in the cold... (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
Mikey914 |
Apr 2 2015, 08:50 AM
I wonder if a washer might be a good solution. Much easier.
euro911 |
Apr 2 2015, 11:24 AM
falcor75 |
Apr 9 2015, 11:24 AM
I just tried and one can use one of 914Rubber's engine shelf grommets (the ones for the water funnel tubes) It's not a 100% snug fit in the hole but it will probably work just fine.
Series9 |
Apr 9 2015, 11:35 AM
G e o r g e |
Apr 9 2015, 11:37 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
mtndawg |
Dec 28 2018, 06:48 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427952627.1.jpg) I think I'll just make a piece of aluminium with the correct sized hole and glue it to the underside of the shelf.... Bumping this because I have a new snorkel tube for my ‘75 and the hole is large while the tube going through the shelf is small just like this photo. Does some have a photo to share showing how you solved this... |
Lo-Fi Version | Time is now: 13th May 2024 - 02:01 AM |
