Series9
Mar 31 2015, 02:39 PM
As most of these are in bad condition, how are you concours guys handling this?
JmuRiz
Mar 31 2015, 02:49 PM
Not sure how the 914rubber ones compare to stock/concours ones, but I know he makes them.
JeffBowlsby
Mar 31 2015, 02:50 PM
914rubber and lots of KY or Glycerin.
Series9
Mar 31 2015, 03:42 PM
I didn't realize Mike made those. That's what we'll do.
falcor75
Mar 31 2015, 11:21 PM
I bought one from Mike but the upper flange that goes thru the engine shelf seems to be too small? or is the hole in my shelf too large? It doesnt seem to be tampered with in any way?
ConeDodger
Mar 31 2015, 11:32 PM
QUOTE(falcor75 @ Mar 31 2015, 08:21 PM)
You're in Sweden Mats...
the hole probably shrunk from the cold last winter???
euro911
Apr 1 2015, 12:39 AM
1. It's Mark ('Mikey914' is Mark's son's member name and
he never posts anything).
2. I've read a few posts where some folks have had to cut the new snorkel (to shorten it) overlap and glue back together after pulling the harness through. I haven't got that far into he restoration to know if I'll need to do that or not
falcor75
Apr 1 2015, 04:33 AM
McMark
Apr 1 2015, 09:32 AM
Another one of the minor differences between early and late cars. I can't remember exactly which is which now or when the changeover is, but there is a difference.
euro911
Apr 1 2015, 01:33 PM
… how'd this happen? (duplicate of post # 7)
Mikey914
Apr 1 2015, 06:42 PM
I made the snorkel from the 75 car my son had, and I don't own any early ones. Never dreamed the hole and harness would change, why would it be necessary, more tooling and expense?
I did make them slightly longer to accommodate 6 conversions, but the 1" can be easily taken up but making the ornamentation35 deg off and bowing it out. Yes they can be cut and overlapped if you want too.
falcor75
Apr 1 2015, 11:30 PM
I think I'll just make a piece of aluminium with the correct sized hole and glue it to the underside of the shelf....
ConeDodger
Apr 1 2015, 11:49 PM
Mikey914
Apr 2 2015, 08:50 AM
I wonder if a washer might be a good solution. Much easier.
euro911
Apr 2 2015, 11:24 AM
A snorkel washer?
falcor75
Apr 9 2015, 11:24 AM
I just tried and one can use one of 914Rubber's engine shelf grommets (the ones for the water funnel tubes) It's not a 100% snug fit in the hole but it will probably work just fine.
Series9
Apr 9 2015, 11:35 AM
QUOTE(euro911 @ Apr 2 2015, 01:24 PM)
A snorkel washer?
is that a euphemism for a cock ring?
G e o r g e
Apr 9 2015, 11:37 AM
QUOTE(Mikey914 @ Apr 1 2015, 05:42 PM)
Weird , just compared mine to the 73 and it's the same size, but my 75 tub looks like Falcor's pic, it is to small.
mtndawg
Dec 28 2018, 06:48 PM
QUOTE(falcor75 @ Apr 1 2015, 09:30 PM)
Bumping this because I have a new snorkel tube for my ‘75 and the hole is large while the tube going through the shelf is small just like this photo. Does some have a photo to share showing how you solved this...
