Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Which is now. (IMG:style_emoticons/default/dry.gif) I had a little trouble coming home from rte 66. I thought it was idle jets buuuutt nooOOOoo! Looks like a good cleaning, compressed air gun and two good rebuild kits in my near future.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Which is now. (IMG:style_emoticons/default/dry.gif) I had a little trouble coming home from rte 66. I thought it was idle jets buuuutt nooOOOoo! Looks like a good cleaning, compressed air gun and two good rebuild kits in my near future. You got 25 days... (IMG:style_emoticons/default/beerchug.gif) Times a wasting... |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,504 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Be sure to check the throttle shafts. after ten years they could be worn and leaking. Oh, and get you work. Times a wasting.
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 961 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I'ts the ethanol in the gas. I had the same problem comming home from the "Tail of the Dragon" last year. The ethanol Eats up the old rubber in the fuel lines and it clogs up the idle jets. Read JAY LANO"S comments in AUTOWEEK March 2 2015. WE"er from the government and we are here to help you.
Elliot Cannon |
All my lines will replaced with plastic lined fuel injection hose. That should help. (IMG:style_emoticons/default/biggrin.gif)
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
You could send them to George, if you don't want to tackle yourself.
Lo-Fi Version | Time is now: 17th June 2024 - 02:26 AM |
