FS: $5 sale! Have a look |
carl k |
Apr 3 2015, 11:27 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
All parts from a 1974 car. All parts plus shipping and I'll happily combine shipping and use flat rate boxes or first class parcel rates where applicable! Handbrake equalizer/connector (used) #914-424-568-00- $5 Front trunk plugs, used, still supple, $5 each Rear trunk light- used, someone painted over the lens- $5 front turn signal lens, right side, crack at one fixing hole but still works, $5 Pressure regulator, untested but looks okay, $5 decel valve, untested, $5 accelerator pedal linkage- $5 used brake master cylinder, should be 17mm, sold as a core since it's locked up, $5 Firewall gasket for two windsheild washer tubes- still supple- $5 trunk or engine lid adjustable rubber bumpers- $5 for the pair window winder handle with escutcheon, good splines but plastic cover doesn't stay snapped- pebble finish- $5 plastic seat belt upper attachment cover- $5 Original hose clamps for fresh air system- $5 for the pair Shipping from San Jose, CA. thanks, Carl |
Lo-Fi Version | Time is now: 17th May 2024 - 09:37 PM |
