All parts from a 1974 car. All parts plus shipping and I'll happily combine shipping and use flat rate boxes or first class parcel rates where applicable!
Handbrake equalizer/connector (used) #914-424-568-00- $5
Front trunk plugs, used, still supple, $5 each
Rear trunk light- used, someone painted over the lens- $5
front turn signal lens, right side, crack at one fixing hole but still works, $5
Pressure regulator, untested but looks okay, $5
decel valve, untested, $5
accelerator pedal linkage- $5
used brake master cylinder, should be 17mm, sold as a core since it's locked up, $5
Firewall gasket for two windsheild washer tubes- still supple- $5
trunk or engine lid adjustable rubber bumpers- $5 for the pair
window winder handle with escutcheon, good splines but plastic cover doesn't stay snapped- pebble finish- $5
plastic seat belt upper attachment cover- $5
Original hose clamps for fresh air system- $5 for the pair
Shipping from San Jose, CA.
thanks,
Carl
