Headlight pivot bushings set of 4 -$8.99, These are the ones that go in the tubes on the bucket assembly |
Mikey914 |
Apr 5 2015, 10:17 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got these finished up and I'm making the ones that go on the metal arms that will be ready in about 6 days. These are necessary to allow the assembly to rotate smoothly.
Cheap enough you can't afford not to replace them. Also working up a new hardware kit to go with these. Don't buy them now if you want to add these in as I'll have them available end of the week. Who wants them? Thanks All. Attached image(s) |
matthepcat |
Apr 5 2015, 10:22 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
One of my headlights vibrates a lot over bumps. Could bushings be the cause of the light to visibly flicker over bumps?
Mikey914 |
Apr 5 2015, 10:30 AM
I't possibly the electrical connection. You can remove the ring to see the status of the connector for the headlamp.
I would inspect that 1st. You can use the filling powder with the Q-bond to rebuild cracked connector blocks http://qbond.net/ If it actually vibrates I suspect the headlamp housing may be missing an adjustment screw. You will be able to check when you look at the connector. Just look for the security of the base assembly. It shouldn't move. Where it moves the most you are probably missing a screw. |
matthepcat |
Apr 5 2015, 10:33 AM
I forgot to mention I can wiggle the whole light assembly very slightly on the side that has the issue.
Mikey914 |
Apr 5 2015, 10:37 AM
I'd bet missing headlight adjuster screw. I'm working on the base blocks ad will them in about 3 weeks at most. You can probably get a used one from a donor car. Check with Rhodyguy, Id bet he or several others that part the cars have them laying around.
Love to sell you the bushings, but I'd bet they are not the problem here. |
Mikey914 |
Apr 5 2015, 10:38 AM
And also check the mounting screws if it's more that just the light assembly that's moving.
raynekat |
Apr 16 2015, 09:17 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Got these finished up and I'm making the ones that go on the metal arms that will be ready in about 6 days. These are necessary to allow the assembly to rotate smoothly. Cheap enough you can't afford not to replace them. Also working up a new hardware kit to go with these. Don't buy them now if you want to add these in as I'll have them available end of the week. Who wants them? Thanks All. I'd like a set. Thx |
Mikey914 |
Apr 16 2015, 09:25 AM
JamesM |
Apr 16 2015, 10:43 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
YES!!! I was just looking for headlight bushings! Are you going to make the other bushings required for the headlight actuators as well? Those are the ones I really need.
Either way, I am in for 3 sets. Waiting for the base blocks and adjuster screws. (I gave all my spare headlight housings to some crazy ass mofo in Sandy who thinks 914s need a light bar?!?!? ) (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Apr 16 2015, 10:59 AM
Actually doing these right now, should probably get another GB thread up but the idea was there are bushings required in the actuator bar (metal one), so why not reproduce the bar with the bushings in it like the later style. I do have a few of the bigger metal bar style bushings, in the works, but kill 2 birds with one stone.
These will be in the ivory like the OEM, but I think these should do well at $10 a set. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:18 PM |
