got914? |
Member ![]() ![]() Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None ![]() |
Ive been searching and cant seem to find the answer.
I know someone on here has the answer. Are the Audi 01E and boxster s the same bellhousing bolt pattern ? |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Ive been searching and cant seem to find the answer. I know someone on here has the answer. Are the Audi 01E and boxster s the same bellhousing bolt pattern ? Yes and no. Not all Boxster S transmissions are the same. The 2001-2008 Boxster S is the same bellhousing as the 01E and most other Audi trannies. Including the Passat, 5000, Fox and 944. |
got914? |
Ok sounds good.
Something else i read on another forum ( not sure if i bookmarked it or not) Is there any truth to the following ? Spline for clutch input shaft has different spline count and 1 mm differnet size ) easy enough to solve) And that the input shaft is 25 MM shorter ?, would this still engage with a KEP setup does anyone know ? |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Ok sounds good. Something else i read on another forum ( not sure if i bookmarked it or not) Is there any truth to the following ? Spline for clutch input shaft has different spline count and 1 mm differnet size ) easy enough to solve) And that the input shaft is 25 MM shorter ?, would this still engage with a KEP setup does anyone know ? KEP would know all of that if they make and adapter and flywheel. If different and if they make the adapters/flywheels for each version you'd get what you need. Perhaps call them, they should be open right now... |
Mike Bellis |
I never measured an 01E but the Boxster 5 & 6 speed is the same 36 spline shaft length as the Audi/VW 012 transmission. I have swapped my Passat 5 speed with my Boxster S 6 speed a couple times. I use the VW 225mm clutch & flywheel.
Audi shares a lot of parts with VW & Porsche. I would guess the 01E main shaft is the same. Andys has a 01E on his LS conversion. He could speak to that. If you want a good, cheap tranny, go to Ebay UK and find a Passat TDI 5 speed tranny code DUK. This has better ratios for a V8 and they run about $400 (or less). I bought my Cayman S 6 speed from England for $700 and spent another $245 air shipping it with TNT. It arrived in 3 days. Cayman S & Boxster S 6 speeds are almost the same. There is a part number difference and a 0.003 final drive ratio difference. The Boxster 5 speed and VW 012 trannies are almost the same. Only the bolt on linkage is different and some of the 012's are not drilled & tapped for the Boxster linkage mounting bolts. |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I never measured an 01E but the Boxster 5 & 6 speed is the same 36 spline shaft length as the Audi/VW 012 transmission. I have swapped my Passat 5 speed with my Boxster S 6 speed a couple times. I use the VW 225mm clutch & flywheel. Audi shares a lot of parts with VW & Porsche. I would guess the 01E main shaft is the same. Andys has a 01E on his LS conversion. He could speak to that. The 01E input shaft is 24mm (15/16") Dia. x 23 spline. Andys |
got914? |
I never measured an 01E but the Boxster 5 & 6 speed is the same 36 spline shaft length as the Audi/VW 012 transmission. I have swapped my Passat 5 speed with my Boxster S 6 speed a couple times. I use the VW 225mm clutch & flywheel. This makes me feel good QUOTE The 01E input shaft is 24mm (15/16") Dia. x 23 spline. Andys Yes i found the porsche is 1 inch by 23 spline, so just for argument sakes run a porsche pressure plate and an audi disc. Or deal with the 1/16 inch diff which is only 1/32 side to side play. |
got914? |
THen I find this on pelican.
Kinda confusing that it shows both sizes of 23.8 (15/16) & 25.4 (1) for the same year boxster s ? Attached thumbnail(s) ![]() |
andys |
Seems odd to me that the majority of foreign and domestic splines are US fractional sizes. My 01E disc was specified as 15/16". At one time, I had a link to a chart of clutch disc splines, and as I recall, all were fractional (inch) sized.
Andys |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I've seen quite a bit of measurement mixing during my projects. The Japanese do it too. I'm talking more than just splines. You can't assume metric is always used based on origin.
Lo-Fi Version | Time is now: 17th June 2024 - 03:09 AM |
