QUOTE(got914? @ Apr 6 2015, 11:23 AM)
Ok sounds good.
Something else i read on another forum ( not sure if i bookmarked it or not)
Is there any truth to the following ?
Spline for clutch input shaft has different spline count and 1 mm differnet size ) easy enough to solve)
And that the input shaft is 25 MM shorter ?, would this still engage with a KEP setup does anyone know ?
KEP would know all of that if they make and adapter and flywheel.
If different and if they make the adapters/flywheels for each version you'd get what you need.
Perhaps call them, they should be open right now...
