914rrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,835 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States ![]() |
Are there any flat paper 914 engine or transmission gaskets that are NLA or are only available in a full set? I am in the process of reproducing some larger paper transmission transfer case gaskets for my 996 Turbo and I was looking for other paper gaskets to fit into the same cut.
I could also use some leads on gasket material suppliers as well as cutting vendors. I have a local vendor who can digitize the gaskets and can cut them on a CNC water jet cutter. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Not sure if NLA but the thin paper gasket for the cover of the taco plate could be
914rrr |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
The one for the trans rear cover is one that we often want without buying the whole kit.
I just reuse mine ... |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
This one?
http://shop.914rubber.com/914-Transmission...m?categoryId=-1 Made a ton of these for Dr Evils' trans clinics so you didn't have to buy the whole set. There's also a member here that has the taco plate gasket as well as a few others that you can print out can cut as you need. So yes you can make them, but they are out there. Attached image(s) ![]() |
stugray |
This one? http://shop.914rubber.com/914-Transmission...m?categoryId=-1 Made a ton of these for Dr Evils' trans clinics so you didn't have to buy the whole set. There's also a member here that has the taco plate gasket as well as a few others that you can print out can cut as you need. So yes you can make them, but they are out there. YES! Thank you! And I thought I had explored every single corner of your website... |
Mikey914 |
Just to clarify my intent here is not to step on your thread, but to point out there are some that are being made or available.
I did drop you a PM to see if I can help out with the ones you need. |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
I found that tail cone gasket at Sunset Porsche individually.
Craig at CAMP |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
See my signature.
914rrr |
Lo-Fi Version | Time is now: 17th June 2024 - 02:01 AM |
