Correct distributer numbers, 914 '74 2.0 |
eldiosyeldiablo |
Feb 15 2005, 11:41 AM
Member Group: Members Posts: 129 Joined: 19-August 03 From: Roswell, GA Member No.: 1,047 |
What are the correct numbers for distributors that will work in my OEM engine?
The is the numbers on my old dist.: JFUDX 4 <-- 0 231 174 011 W 039 905 205 A The rebuilt one is: JFURX 2 <-- 0 231 163 018 W 311 905 205 O The built one is incorrect because it does not fit and the timing mark is in the incorrect location. Is the numbers on my old dist the only one that will work? -David |
skline |
Feb 15 2005, 11:44 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I think it has something to do with the injection system also. They were different for the 1.8 and the 2.0. You may have got the one for the worng engine. I could be mistaken so I will leave it at that.
Gint |
Feb 15 2005, 06:01 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
David,
Go look at Brad Anders' site. It lists your dizzy number. I didn't look much further. Lots of good info there generally speaking... |
Mueller |
Feb 15 2005, 06:03 PM
you are correct, the 1.7 and 2.0 distributors are totally different than the 1.8 |
eldiosyeldiablo |
Feb 16 2005, 07:53 AM
Thank you Mike/Gint. I had forgotten about Brad Ander's website.
Bleyseng |
Feb 16 2005, 09:05 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The 311 dizzy is for a Type 3! Make sure you get a 022 or 039 dizzy or have yours rebuilt. Mostly its just the new bearing that needs to be machined in and then you can install the FI points .
Lo-Fi Version | Time is now: 17th May 2024 - 05:23 PM |
