Auxiliary Air Regulator Connection on 1.7 |
lennyhope |
Apr 7 2015, 03:38 PM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
Where/what does the electrical connector at the bottom of the Aux. Air Regulator connect to??
Bob L. |
Apr 7 2015, 05:19 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
There's a 4 pin connector from the ignition harness that plugs into the relay board, one of those. I think it's white.
See the wire running across the bottom of the diagram... http://www.pelicanparts.com/914/parts/Elec...lectric_73C.jpg |
JeffBowlsby |
Apr 7 2015, 09:46 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The red wire on the AAR connects with a single white wire on the ignition harness, should have a single pole box housing on it.
914_teener |
Apr 8 2015, 07:32 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Don.t forget to put on the box housing over the spade connector........ask me how I know.
Old Yella |
Apr 8 2015, 08:06 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
how do you know?
Apr 8 2015, 11:59 PM
Because he kept popping the fuse that powers the fuel pump, that's how.
--DD |
lennyhope |
Apr 9 2015, 12:48 AM
Because he kept popping the fuse that powers the fuel pump, that's how. --DD Thanks for the replies. Very helpful.... (IMG:style_emoticons/default/smile.gif) |
9won4 |
Apr 18 2015, 07:44 PM
Newbie Group: Members Posts: 47 Joined: 2-October 13 From: Las Vegas Member No.: 16,465 Region Association: Southwest Region |
Been popping fuses...unplugged AAR....car starts. Removed it, there is no bare wire touching, shrink wrapped all connections, reinstalled it. Started up this morning and about a mile into the drive the fuse popped again. Are there some internals in the AAR that could be causing this? Thanks!
JeffBowlsby |
Apr 18 2015, 09:02 PM
Power through the AAR case maybe shorting to the case. Direct to ground. Fuse pop-ola.
Apr 18 2015, 09:07 PM
If you open the AAR up, you'll see that there is a coil of bare wire sitting on the bottom of the can. There is some cardboard between the coil and the can. If the wire is moving around, it could be shorting to the can.
Pry back the crimped lip around the upper edge of the can to pull the top off and the guts out. That will show you the heater wire and insulator. --DD |
9won4 |
Apr 18 2015, 09:36 PM
Thanks Dave...Guess I just found a project for tomorrow! Thanks
Tom |
Apr 19 2015, 03:30 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
A popular place for the red wire to partially short to ground is where the red wire enters the bottom of the AAR. When you check it and if this is the problem, cut the connector off of the red wire where it connects to the white wire, slip a small piece of heat shrink over the red wire and push it up to where the bare spot is, heat it up, and then crimp on a new connector on the red wire. If it still blows fuses, then the hard way must be accomplished - opening up the AAR and seeing why it is shorting.
Tom |
Lo-Fi Version | Time is now: 18th May 2024 - 01:46 AM |
