lennyhope
Apr 7 2015, 03:38 PM
Where/what does the electrical connector at the bottom of the Aux. Air Regulator connect to??
Bob L.
Apr 7 2015, 05:19 PM
There's a 4 pin connector from the ignition harness that plugs into the relay board, one of those. I think it's white.
See the wire running across the bottom of the diagram...
http://www.pelicanparts.com/914/parts/Elec...lectric_73C.jpg
JeffBowlsby
Apr 7 2015, 09:46 PM
The red wire on the AAR connects with a single white wire on the ignition harness, should have a single pole box housing on it.
914_teener
Apr 8 2015, 07:32 PM
Don.t forget to put on the box housing over the spade connector........ask me how I know.
Old Yella
Apr 8 2015, 08:06 PM
how do you know?
Dave_Darling
Apr 8 2015, 11:59 PM
Because he kept popping the fuse that powers the fuel pump, that's how.
--DD
lennyhope
Apr 9 2015, 12:48 AM
QUOTE(Dave_Darling @ Apr 9 2015, 05:59 AM)
--DD
Thanks for the replies. Very helpful....
9won4
Apr 18 2015, 07:44 PM
Been popping fuses...unplugged AAR....car starts. Removed it, there is no bare wire touching, shrink wrapped all connections, reinstalled it. Started up this morning and about a mile into the drive the fuse popped again. Are there some internals in the AAR that could be causing this? Thanks!
JeffBowlsby
Apr 18 2015, 09:02 PM
Power through the AAR case maybe shorting to the case. Direct to ground. Fuse pop-ola.
Dave_Darling
Apr 18 2015, 09:07 PM
If you open the AAR up, you'll see that there is a coil of bare wire sitting on the bottom of the can. There is some cardboard between the coil and the can. If the wire is moving around, it could be shorting to the can.
Pry back the crimped lip around the upper edge of the can to pull the top off and the guts out. That will show you the heater wire and insulator.
--DD
9won4
Apr 18 2015, 09:36 PM
Thanks Dave...Guess I just found a project for tomorrow! Thanks
Tom
Apr 19 2015, 03:30 PM
A popular place for the red wire to partially short to ground is where the red wire enters the bottom of the AAR. When you check it and if this is the problem, cut the connector off of the red wire where it connects to the white wire, slip a small piece of heat shrink over the red wire and push it up to where the bare spot is, heat it up, and then crimp on a new connector on the red wire. If it still blows fuses, then the hard way must be accomplished - opening up the AAR and seeing why it is shorting.
Tom
