what next 914? |
what next 914? |
Joshporsche |
Feb 15 2005, 04:00 PM
914 addiction Group: Members Posts: 47 Joined: 27-July 04 From: St. George, UT Member No.: 2,408 |
I finally got a 914, it hasn't run for about 2 years. the gas tank was empty, oil empty.
I put new oil and gas, new fuel pump-it was shot and new points. I have it running but it only gets to about 2500 rpm. What would you do next to get it back to normal use driving? thanks |
bondo |
Feb 15 2005, 04:03 PM
Timing!!!
mharrison |
Feb 15 2005, 04:06 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Carbs or Fuel Injection?
914helo |
Feb 15 2005, 04:08 PM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
It also will probably need a valve adjustment. Make sure to get new gaskets for the valve covers, you don't need any sealer. I've read other posts here about preferred methods. The first time will be slow, but then you get quicker (and swear more). The pelican board has a tech write-up I believe if you need one. Congrats on getting a 914 (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
ArtechnikA |
Feb 15 2005, 04:09 PM
yes, timing, valve adjustment, probably a can of Berryman B-12 (or gas-station Techron, or Jectron/Ventil Sauber) to get the gunk out of the injectors.
presuming it still has FI - we need details... check the auxiliary air valve, check all the vacuum hoses, especially the hose to the manifold pressure sensor. presuming it is a D-Jet car -- we need full details... |
JmuRiz |
Feb 15 2005, 04:15 PM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'd have checked the tank for rust, if it was sitting empty for 2 years, chances are there is rust in the tank. Also look into the things the others mentioned
Joshporsche |
Feb 15 2005, 04:20 PM
wow, thanks for the instant input.
it's a 73 1.7 fuel injected 914. Good condition without rust except the battery area. I did the timing and all the hoses are hooked up. When i bought it-the valve covers were off and i put them back on with new gaskets. but i didn't adjust them. thanks again. |
mharrison |
Feb 15 2005, 04:24 PM
Fuel filter maybe??? Also, I would think maybe the valve covers were off for a reason. You may have 1/2 of a valve job!!! heh..heh..
Joshporsche |
Feb 15 2005, 04:32 PM
I replaced the fuel filter but i used one thats just common from auto zone. would that affect the performance? How much does a valve tune up usually cost on a 914.. I'm not that talented like the rest of you.
Lo-Fi Version | Time is now: 27th May 2024 - 11:15 PM |
