crankshaft standard or turned |
80cap |
Apr 8 2015, 03:42 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I just finished splitting my 2.0 case and the main bearing is marked .25mm. I am assuming that this indicates the crank has been turned. If so is this a lot or just a clean up grind? I very new to the Vw type engine.
Thanks Brian |
SLITS |
Apr 8 2015, 04:20 PM
That is 0.010 undersize, the first cut. The second cut would be 0.50 mm or 0.020 under.
At 10 under you are not really into the soft metal as yet supposedly. Hopefully you can find bearings. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:11 PM |
