Can't separate Speedo Drive from Right Angle Drive, any tricks to it? |
RazorbackFan78 |
Apr 10 2015, 02:01 PM
3 different layers of paint helps protect if from rust Group: Members Posts: 136 Joined: 29-March 13 From: Bentonville, AR Member No.: 15,709 Region Association: South East States |
So....Separating the Speedo Drive from the Right Angle Drive. Is there a trick to this? I can see some red selant or something from the PO when I pulled the speedo drive out of the trans. I'm worried they're somehow fused together with loctite or something. There's not much room for leverage under the car. I've thrown the vice grips on the speedo side and tried wrenching the right angle off. No luck yet. Just wanted to check in with the group before I get mid-evil on it and accidentaly break the right angle drive.
Thx in advance |
RazorbackFan78 |
Apr 12 2015, 06:38 AM
bump
oldie914 |
Apr 12 2015, 12:03 PM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
Heat the housing with a propane torch. Aluminum expands more than steel so that should looosen it.
Dr Evil |
Apr 12 2015, 12:22 PM
Pretty much not feasible with it removed from the tail cone unless you have a special spanner wrench. Heating it might work, but how are you going to grab the base? Also, you will need to replace the seal inside after.
euro911 |
Apr 12 2015, 12:33 PM
(IMG:style_emoticons/default/agree.gif) I've always unscrewed the angle drive first (while the speedo drive unit was still in the nose cone).
Larmo63 |
Apr 12 2015, 01:39 PM
Not to hijack, but I removed my angle drive, cleaned it, it appears to be working perfectly. New speedo cable, tested with a drill motor from the rear, (works) yet no working speedometer. I tried to get the aluminum part out of the trans, marred it up fairly good, and, yes, I took the retaining bolt out. I gave up, still nothing. Why the big mystery here?
Can someone just explain the basics? |
76-914 |
Apr 12 2015, 03:54 PM
Screw that nut back in then use the piece as an extension so you can get it to "wobble" as you pull it out. Tap it very lightly w/ a hammer if you need to. I've got a couple of rebuilt ones laying around if you need one.
Lo-Fi Version | Time is now: 17th May 2024 - 07:37 PM |
