High Amp Alternator, bolt in application |
McMark |
Apr 13 2015, 04:03 PM
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ). It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif) I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
McMark |
Apr 13 2015, 05:43 PM
QUOTE Pulley fan or rear cooling duck??? The alternator is sold just as it's shown. I am probably going to merge a 914 alternator rear housing and the one that came on this unit. Should be able to make that work pretty easily. QUOTE So, what happens when the voltage regulator fails? How much heavier and what might be the cost? The VR may be replaceable, but I expect this new stuff to be much more robust. Which means, I expect to never have to touch this alternator/VR again ever. I didn't weigh it, but I would guess around double the weight. Cost TBD, but a rebuilt unit is under $100, and this will be at least triple that, plus... (IMG:style_emoticons/default/ph34r.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:34 PM |
