High Amp Alternator, bolt in application |
McMark |
Apr 13 2015, 04:03 PM
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ). It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif) I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
Dtjaden |
May 16 2015, 10:29 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Hi Mark,
Electric heaters have been discussed before and usually the conclusion has been that they will not provide enough heat, but --- I decided to revisit the formulas for heat generation and temperature rise in a confined space. 600 watts = 2047 btu I estimated the 914 cabin space as 75 cubic feet. I also assumed it was poorly insulated. 2047 btu's will raise the temperature of that space between 25 and 30 degrees. This assumes that the cabin air is recirculated, not outside air being heated and directed into the cabin. So...I think this may have a chance of working out. If so, I may have to drive up to see you since my car has no heat (headers)! Darryl |
Lo-Fi Version | Time is now: 18th May 2024 - 03:38 PM |
