| McMark |
Apr 13 2015, 04:03 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ). It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif) I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif) Attached image(s)
McMark High Amp Alternator Apr 13 2015, 04:03 PM
Elliot Cannon So, what happens when the voltage regulator fails?... Apr 13 2015, 04:27 PM
Krieger Good work! Apr 13 2015, 04:33 PM
Geezer914 Pulley fan or rear cooling duck??? Apr 13 2015, 04:47 PM
Kansas 914
:popcorn: Apr 13 2015, 05:27 PM
Elliot Cannon
:popcorn:
Apr 14 2015, 01:12 AM
worn
Noticed that one too. Very common though. So ... Apr 22 2015, 11:03 AM
Elliot Cannon
Noticed that one too. Very common though. So... Apr 22 2015, 11:19 AM
Kansas 914
I think even the HVAC people spell it that way n... Apr 22 2015, 01:32 PM
euro911 I think even the HVAC people spell it that way now... Apr 22 2015, 06:36 PM
worn There is warm air at the North Pole?
Also i can h... Apr 22 2015, 07:03 PM
McMark
The alternator is sold just as it's shown. I... Apr 13 2015, 05:43 PM
McMark Looked and theres a fan inside. :thumbsup: Apr 13 2015, 11:51 PM
Bartlett 914
Look... Apr 14 2015, 06:45 AM
euro911 Looks good, Mark. Will the OEM alternator tin fit ... Apr 14 2015, 02:17 AM
McMark
Just heard back that the alternator is the correc... Apr 22 2015, 10:53 AM
Bartlett 914
Just heard back that the alternator is the corre... Apr 22 2015, 01:53 PM
McMark I'll weigh it tomorrow... :thumbsup: Apr 22 2015, 09:14 PM
falcor75 Since I'm going the efi route I think I'm ... May 15 2015, 01:03 PM
McMark Efi doesn't need high amps. It's more hot ... May 15 2015, 07:56 PM
worn
Efi doesn't need high amps. It's more hot... May 15 2015, 08:09 PM
euro911 Any updates, Mark? May 15 2015, 08:00 PM
boxsterfan Awesome on this high output alternator!! ... May 15 2015, 08:12 PM
McMark
Awesome on this high output alternator!! ... May 15 2015, 09:52 PM
boxsterfan
Awesome on this high output alternator!... May 16 2015, 12:23 AM
euro911 Yep, an electric heater's been on my list for ... May 15 2015, 10:58 PM
Dtjaden Hi Mark,
Electric heaters have been discussed bef... May 16 2015, 10:29 AM
sixnotfour I have used this one for two years ..works great..... May 16 2015, 01:08 PM
boxsterfan
I have used this one for two years ..works great.... May 16 2015, 04:46 PM
Dtjaden Just a caution on the heat output claims many of t... May 16 2015, 07:40 PM
boxsterfan
Just a caution on the heat output claims many of ... May 16 2015, 07:44 PM
McMark Installed this today. Went just as smooth as expec... May 24 2015, 08:09 PM
boxsterfan :beer3: May 24 2015, 09:40 PM
boxsterfan Did you ever try your electric heat unit? Seat he... Aug 8 2015, 12:29 PM
MSHax That's pretty cool! Back in the day I modi... Aug 8 2015, 12:39 PM
McMark Not yet. After the move and I get settled in the ... Aug 8 2015, 12:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:18 PM |
