914 Red G light on, what is it? |
Joshporsche |
Feb 16 2005, 02:54 PM
914 addiction Group: Members Posts: 47 Joined: 27-July 04 From: St. George, UT Member No.: 2,408 |
What is the Red G light on my guages? Why is it on? what can i do to fix it?
bd1308 |
Feb 16 2005, 02:57 PM
check your:
*Alternator belt for slipping *Voltage Regulator *Alternator failure...does happen! |
ChrisReale |
generator, or alternator light
Rouser |
Feb 16 2005, 03:02 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Worst case senario: "G" is the alternator light; you're probably running on the battery only. If it's glowing while the ignition is off, one of the alternator's internal diodes is probably shorted, draining your battery while it's sittting there parked.
Than again, you might've just snapped or thrown a fan belt. Either way, you gotta pop the engine lid and take a look. |
AZ914 |
Feb 16 2005, 05:04 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
My 'G' light was also on when I experienced a short in my electrical system. Car ran fine, just that I had blown a fuse. Check that too.
skline |
Feb 16 2005, 05:12 PM
I had that happen last week. The first thing to check is the fan belt, make sure it is on and tight. If that is not it, take the 2 small screws from the voltage regulator and pull it out and swap in another one. If that doesnt fix it, you are looking at replacing the alternator. I would pull the alternator and take it to your FLAPS and have them check it. Good luck to you. Mine was only the VR. 5 minute fix.
Aaron Cox |
Feb 16 2005, 05:16 PM
Yes in fact it is your alternator idiot light.
Voltage regulator? Alternator Diodes? Edited for cranky..... |
Bleyseng |
Feb 16 2005, 06:37 PM
You are about to run out of gas! The yellow reserve lite must be dead, but the red G lite comes on when you are dead on empty!
no lites-lots of gas yellow- on reserve 'bout a gallon left red- you're outta gas!! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
redshift |
Feb 16 2005, 06:39 PM
-snickers-
It's a G-ThanG. OG.. Bounce ta dat! -marsbar- M_dawg |
SLITS |
Feb 16 2005, 06:53 PM
It is a warning that Z or A-aron Admin are wearing their "G" strings and should be avoided at all costs. Properly programmed, works within a 200 mile radius.
I wish Z's girl would learn to wipe correctly before posing for pictures...kinda detracts from the bunny ears. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
Joe Bob |
Feb 16 2005, 07:12 PM
It's a muddy hand print from the unwashed....
Joe Bob |
Feb 16 2005, 07:13 PM
Oh by the way...you are an....
SLITS |
Looks like a handprint from Sasquatch. Did you shave?
Elliot_Cannon |
Feb 16 2005, 08:46 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
There is a fuse for "indicators". If it is blown, the light will come on. Check the fuse first. cheers, Elliot |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:10 AM |
