Clutch Failure, pedal to the floor! |
mikedsilva |
Apr 19 2015, 01:29 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
What's the part # on the lever? Looks like it's not long enough (IMG:style_emoticons/default/popcorn[1].gif) I think you are right... Is my pivot ball in the same position as everyone elses? If it could be moved in closer, it would fix my problem... Part number on my fork is 9011167111r (hard to read - the 6 could be something else) I cleaned up the bits and reassembled.. Here's what it looks like... (IMG:http://i1260.photobucket.com/albums/ii568/mikedsilva/914/DSC02523_zpsyqfbho0b.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428568.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428569.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428571.3.jpg) |
mikedsilva |
What's the part # on the lever? Looks like it's not long enough (IMG:style_emoticons/default/popcorn[1].gif) I think you are right... Is my pivot ball in the same position as everyone elses? If it could be moved in closer, it would fix my problem... Part number on my fork is 9011167111r (hard to read - the 6 could be something else) I cleaned up the bits and reassembled.. Here's what it looks like... (IMG:http://i1260.photobucket.com/albums/ii568/mikedsilva/914/DSC02523_zpsyqfbho0b.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428574.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428578.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429428578.3.jpg) |
mikedsilva |
Apr 19 2015, 01:59 AM
googling that part number bring up NOTHING....
rmdinmd |
Apr 19 2015, 05:22 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
the PET say the part # should be 90111671200.
Tbrown4x4 |
Apr 19 2015, 05:32 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Soooooo.... What's the story?
New clutch? New Trans? Bought used? I think we all agree that fork isn't correct, but how did it get there? |
JawjaPorsche |
Apr 19 2015, 05:47 AM
Put out a Wtb in classifies..
Luke M |
Apr 19 2015, 06:10 AM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I've got a clutch fork sitting around in a box someplace here.
Shoot me a pm if you still need one. BTW it looks like something was rubbing on your clutch fork. It could've caused it to be knocked off the bearing unless it was caused after it came off? |
walterolin |
Apr 19 2015, 07:56 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
How about this: http://forums.pelicanparts.com/3245220-post1.html
My fork reads: 9011167120R, 1970, 1.7 |
Mike Bellis |
Apr 19 2015, 09:55 AM
Many of us have placed a washer under the ball stud to change the fulcrum point, this works well but there are few threads left.
Does anyone have a measurement of the ball and threads? There are thousands of ball studs on the market. I wonder if there is a good aftermarket choice with longer threads. |
mikedsilva |
Apr 19 2015, 12:58 PM
Soooooo.... What's the story? New clutch? New Trans? Bought used? I think we all agree that fork isn't correct, but how did it get there? I have only had the car a month or so. The previous owner had it 5 years and had all the work done. Apparently he had a new clutch kit installed by his local shop (different State to where I live). Unfortunately, I am on my own... he didn't know much about mechanicals and I doubt he wants to know about the issues now! |
pilothyer |
Apr 19 2015, 03:53 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Obtain the proper clutch fork and you'll be golden.....don't know what the one you have goes in, but it is clearly the wrong one. You need #90111671200 maybe go ahead and get the 2 plastic guides if yours were buggered up.
ThePaintedMan |
Apr 19 2015, 07:10 PM
(IMG:style_emoticons/default/agree.gif) Definitely not the right fork, or it's at minimum, not engaging correctly.
Interesting in your pictures too - it looks like it was rubbing on the pressure plate as well - see the big gouge in the fork? I bet it was barely engaging before and the pressure plate spinning eventually knocked it off completely. OR vice versa: it came off and then started rubbing on the pressure plate. |
mikedsilva |
Apr 19 2015, 10:01 PM
I borrowed a fork from a friend for comparison.. they looked almost identical...
Apart from the location of the ball pivot socket.. On my fork, it is very close to the edge of the fork. On my friends fork, it is a few mm inset. That would have to account for some of the difference... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429502476.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429502476.2.jpg) |
euro911 |
Apr 19 2015, 10:56 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
In doing a little more research, found a guy on ebay selling one from a '73 with part# 901.116.712.00 (as Jerry stated) ebay link
Looks just like the one your friend has. Did you test fit it yet? |
mikedsilva |
Apr 20 2015, 12:32 AM
In doing a little more research, found a guy on ebay selling one from a '73 with part# 901.116.712.00 (as Jerry stated) ebay link Looks just like the one your friend has. Did you test fit it yet? Not yet.. I'm still at work! it's Monday afternoon here... |
mikedsilva |
Apr 20 2015, 01:52 PM
Test fit shows perfect fitment!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559527.1.jpg) While I had the gearbox off, a friend loaned me his flywheel lock tool.. so I figured I should check out the slight oil weep.. I've heard of gallery plugs leaking but I think in my case, it is the rear oil seal.... Notice the oil dribbling out... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559527.2.jpg) After a quick clean with brake cleaner... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559528.3.jpg) I can see oil at the bottom of the seal... does that mean it's toast? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559528.4.jpg) I've ordered a new seal, but somehow, I think there is more I should be doing while in here... Does my clutch look OK? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559528.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1429559529.6.jpg) |
maf914 |
Apr 20 2015, 01:58 PM
If the clutch fork issue has been solved, you won't need this attachment. Otherwise, I thought it might be helpful. Is the retaining bracket, item number 6, complete and in place?
Attached thumbnail(s) |
mikedsilva |
Apr 20 2015, 02:37 PM
If the clutch fork issue has been solved, you won't need this attachment. Otherwise, I thought it might be helpful. Is the retaining bracket, item number 6, complete and in place? HI, thanks for posting... yes it is in place. Whilst I haven't mounted the trans back in the car, I believe it should now work properly. |
euro911 |
Apr 20 2015, 05:05 PM
Looks like you have the correct lever now (IMG:style_emoticons/default/beerchug.gif)
If you can obtain a new rear main seal fairly quick, I'd replace it while you have the opportunity. I'd suggest a Victor Reinz seal if possible. I'll also recommend that you get a new flywheel O-ring and a new lock plate (both are relatively inexpensive parts). |
mikedsilva |
Apr 20 2015, 06:52 PM
Looks like you have the correct lever now (IMG:style_emoticons/default/beerchug.gif) If you can obtain a new rear main seal fairly quick, I'd replace it while you have the opportunity. I'd suggest a Victor Reinz seal if possible. I'll also recommend that you get a new flywheel O-ring and a new lock plate (both are relatively inexpensive parts). Hi the "lock plate".. is that just the flimsy metal washer that goes between the flywheel bolts and the flywheel itself? Also, what is the purpose of the felt washer... When i removed my flywheel last night, I am certain there was no felt washer.. And the needle-roller bearing looked pretty dry too... |
Lo-Fi Version | Time is now: 31st May 2024 - 10:11 PM |
