Dang it man!, Bought front sway bar, no mounting holes!! |
BK911 |
Apr 17 2015, 10:50 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Just bought a front sway bar ASSuming all 914s had the holes in the tub for the bar to pass through. I mean, seriously? Now what? Really don't want to cut the tub. Do I have some sort of freak, or did other 914s come this way?
colingreene |
Apr 17 2015, 10:51 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Very common.
you need to cut the car. |
Larmo63 |
Apr 17 2015, 10:52 AM
You have to pull the tank and drill. It isn't that big of a deal, lots of threads here and on the Pelican board.
You can do this. |
rjames |
Apr 17 2015, 11:11 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
5 minute job after the tank is pulled. Marks are even already there showing you where to drill.
Apr 17 2015, 11:33 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Very common. you need to cut the car. (IMG:style_emoticons/default/agree.gif) Most 914s didn't come with sway bars, you'll have to cut the tub ... (IMG:style_emoticons/default/sawzall-smiley.gif) |
BK911 |
Apr 17 2015, 11:51 AM
Hmm, I will have to drink on this.
Not a real fan of cutting the tub, especially since I really dont *need* a sway bar. Thanks guys! |
JamesM |
Apr 17 2015, 12:00 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
BuddyV |
Apr 17 2015, 12:05 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
My mechanic skills are about as lame as you get (although I take things APART very, very well)..... and I have done this. I would call it more "drilling" than cutting, unless I am forgetting a step.
Regardless, it's totally worth it. After the first turn I took in my car after installing the front sways bar, there was an audible 'Holy SH#$!" .... and pulling the tank gives you a view into an area that one rarely sees. Good to know how things are looking down there..... much like a colonoscopy. Do it.... it's a good thing. (both things) Cheers. (IMG:style_emoticons/default/drunk.gif) |
914_teener |
Apr 17 2015, 01:06 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Hmm, I will have to drink on this. Not a real fan of cutting the tub, especially since I really dont *need* a sway bar. Thanks guys! No....you don't. I take it if you don't want the sway bar. (IMG:style_emoticons/default/laugh.gif) |
Kansas 914 |
Apr 17 2015, 01:14 PM
Hmm, I will have to drink on this. Not a real fan of cutting the tub, especially since I really dont *need* a sway bar. Thanks guys! How rare is the "tub"? Front anti-sway bars is one of the best add-on upgrades to a 914. It does make a difference and once you have driven one you won't go back. Just my .02 I am facing the same situation on my '74 - and looking forward to it since I need to pull the tank anyway. |
914_teener |
Apr 17 2015, 01:27 PM
My mechanic skills are about as lame as you get (although I take things APART very, very well)..... and I have done this. I would call it more "drilling" than cutting, unless I am forgetting a step. Regardless, it's totally worth it. After the first turn I took in my car after installing the front sways bar, there was an audible 'Holy SH#$!" .... and pulling the tank gives you a view into an area that one rarely sees. Good to know how things are looking down there..... much like a colonoscopy. Do it.... it's a good thing. (both things) Cheers. (IMG:style_emoticons/default/drunk.gif) I disagree....re-installing the fresh air fan is like a colonoscopy. |
SLITS |
Apr 17 2015, 01:44 PM
Make sure your A-arms have the tabs on them.
forrestkhaag |
Apr 17 2015, 01:52 PM
the tabs on the A-Arms are essential even if you have to weld them on or find other arms with them / but the job is easy: go to Home Depot or your local hardware store, buy two bits / a one inch diameter hole bit and a 3/8"bit and you are mostly there. Including the tank removal, it is a four hour job if done well and you can "clean up" any neglected fuel hose issues while you're at it.
Have fun. (IMG:style_emoticons/default/beerchug.gif) |
Chris H. |
Apr 17 2015, 02:11 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
There are a bunch of threads on the subject. It sounds pretty easy. I think even I could do it. Kent did a nice job explaining it....start at post 278...
Swaybar install The measurements in mm are nice. He also references the Pelican install article. |
pilothyer |
Apr 17 2015, 02:19 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
My mechanic skills are about as lame as you get (although I take things APART very, very well)..... and I have done this. I would call it more "drilling" than cutting, unless I am forgetting a step. Regardless, it's totally worth it. After the first turn I took in my car after installing the front sways bar, there was an audible 'Holy SH#$!" .... and pulling the tank gives you a view into an area that one rarely sees. Good to know how things are looking down there..... much like a colonoscopy. Do it.... it's a good thing. (both things) Cheers. (IMG:style_emoticons/default/drunk.gif) I disagree....re-installing the fresh air fan is like a colonoscopy. You do not need to remove the fresh air box to pull the fuel tank. |
BK911 |
Apr 17 2015, 04:09 PM
Wow, sounds like everybody thinks I should start drilling!!
Had the fuel tank out before to condition the tank and replace fuel lines. Also have the tabs on the a arms. Sound like a no brained? I just hate cutting up an original car. I may, but haven't had enough beers yet to make a decision. |
Harpo |
Apr 17 2015, 04:15 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
What about the 911 set up where the sway bar goes under the car? Supposedly it is bolt on only
David |
Apr 17 2015, 04:46 PM
What about the 911 set up where the sway bar goes under the car? Supposedly it is bolt on only Bolt on, no cutting and works well. Only downside, it's not adjustable. (IMG:style_emoticons/default/smile.gif) |
Chris H. |
Apr 17 2015, 04:49 PM
But don't you need a 911 front suspension to bolt that to or no (IMG:style_emoticons/default/confused24.gif) ?
bigkensteele |
Apr 17 2015, 05:02 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Wow, sounds like everybody thinks I should start drilling!! Had the fuel tank out before to condition the tank and replace fuel lines. Also have the tabs on the a arms. Sound like a no brained? I just hate cutting up an original car. I may, but haven't had enough beers yet to make a decision. If you already have the tabs on the a arms, then they probably aren't original anyway. If your car is not a concours queen, why not? There is no down-side if you do it properly. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:06 PM |
