| iiibdsiil |
Feb 16 2005, 10:08 PM
Needs Door Locks ![]() ![]() ![]() Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
Did you enter through the intake or exhaust port? |
| Jake Raby |
Feb 16 2005, 10:44 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
.And ALWAYS tape up intake ports while working on the engine with open intakes... (or fill them with rags)
That head is very repairable, just make sure it didn't cause a hot spot and crack.. If its cracked it'll have to be drilled and then welded. |
| scotty b |
Feb 17 2005, 08:37 AM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I guess thats better then a "foriegn object" in her cylinder (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Attached image(s)
| sanman |
Feb 17 2005, 09:07 AM
Leaving California ![]() ![]() Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
prolly didnt do any damage, put er back together she'll be fine (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
| Joe Ricard |
Feb 17 2005, 09:11 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Just be carefull of hot spots (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) heard that can happen during prolonged use and lack of lube. Back to chopstick guy. Glad to see that Opera guy changed his AVATAR from cam lobes to Chopsticks. Gets the heat off me. |
| maf914 |
Feb 17 2005, 12:01 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Did she notice? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
| DJsRepS |
Mar 8 2005, 06:19 AM
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
I still remember the plastic chop stik in the cyl trick. I dropped a valve drove it home after it bent and jammed in the guide did min dammage. Tough motors.
Lo-Fi Version | Time is now: 8th December 2025 - 01:20 AM |
