How to connect shift rod to transmission ball |
puffinator |
Apr 19 2015, 06:36 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
Apr 19 2015, 06:43 PM
Bushing goes on ball
Metal piece above goes on bushing Rod slides into metal piece above Allen head cone screw goes into shift Rod. |
puffinator |
Apr 19 2015, 06:58 PM
Bushing goes on ball Metal piece above goes on bushing Rod slides into metal piece above Allen head cone screw goes into shift Rod. The deldrin or whatever bushing inside the metal has a diameter of 16mm and the ball on the transmission is a little over 18mm. The meta piece in the picture with the bushing doesn't want to go over the ball even with a lot of force. Do I just try to force it on - hammer? |
Apr 19 2015, 07:00 PM
Bushing goes on ball first, all alone
Then metal piece goes over bushing. It expands enough to fit on,the ball, a good smack with the heal of yr hand should do it Large channel lock pliers also work. |
Mike Bellis |
Apr 19 2015, 07:04 PM
You can also boil the bushing in water and it will pop on while hot.
You should add a little grease inside the bushing before fitting. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:13 PM |
