Rear Trunk Latched and No button, Hope there's no dead body in there! |
mharrison |
Feb 16 2005, 09:52 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
My new car came with the rear trunk closed. It has the PORSCHE reflector and no button behind it. The reflector is of course, screwed on from inside the trunk. There is a mystery button in the home made center console, but it doesn't appear to do ANYTHING.
So, do any of you guys have a magic trick for getting in there without a sawsall? |
skline |
Feb 16 2005, 09:56 PM
Look for a small hole in the center of the S, if there is not one there you can drill a 1/8 inch hole and push a coat hanger through it and pop the trunk.
Drill the hole dead center on the S, I do mean dead center in the black, you will just have to trust me on that one. |
skline |
Feb 16 2005, 09:57 PM
Wait, before you drill it, take a picture and post it so I can be sure!!!
iiibdsiil |
Feb 16 2005, 09:59 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
I like "Trust me on this" then "HOLD ON!"
skline |
Feb 16 2005, 10:00 PM
Well, it makes a difference if he has a cut down 911 or the one that was made for the 914.
bondo |
Feb 16 2005, 10:01 PM
Mine had a cable that came out next to the engine lid cable. Also look for a pull cable in the engine compartment. If it was wired for an electic solenoid, the wiring would also have to go through the engine compartment. The only stock wiring to the rear of the engine compartment goes through the engine compartment on the driver's side. Anything extra going back there is *probably* the trunk release wiring.
*edited by me for bad spelling* |
iiibdsiil |
Feb 16 2005, 10:03 PM
I figured you had a good reason, it just made me laugh. I had to double read your post because "trust me on this" so I'm like what's the next person go to say, and boom it's "HOLD ON!" I guess I'm just easily amused. |
Rockaria |
Feb 16 2005, 10:04 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Before you go a drillin' Maybe you should follow the wires from the mystery button and see if they go towards the trunk if they do then put a quick 12 volts across those wires and see what happens...
It'll either open the trunk or .... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
skline |
Feb 16 2005, 10:08 PM
Also look down behind the license plate for a cable hanging down, some guys put an emergency cable under there to open it in the event of a dead battery.
bperry |
Feb 17 2005, 12:03 AM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Also, keep in mind that the solenoids tend to be underpowered.
Sometimes they don't have the force needed to pull down without some assistance. So try pushing down on on the trunk lid directly above the latch before pushing the button. Ideally, have a friend push on the trunk lid while you push the button. Depending on how the button was wired, you may have to have the car running as well. If none of that works, It is probably a good idea to track down the wires to make sure that there is no inline fuse that is blown. I also have seen other treads of people using coat hangers inserted through the plastic cups at the front of the trunk to unlock the trunk. Good luck. --- bill |
JoeSharp |
Feb 17 2005, 12:22 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Ya know its dark out and I just wanted to try. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So Here it is. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Joe P.S. This is a cut down 911. Attached image(s) |
skline |
Feb 17 2005, 01:11 AM
Mine was lower than that Joe, it was on the black in the middle of the S, I think either way it would be close enough to get the wire in to trip the button.
Aaron Cox |
Feb 17 2005, 01:55 AM
joe...
izat the reflector i gave ya? |
JoeSharp |
Feb 17 2005, 07:05 AM
Aaron: Yes, Thank You. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe |
mharrison |
Feb 17 2005, 08:09 AM
I'll have to check mine to see if it's for a teener or a tail-dragger. I do know that it has a plexiglass looking mounting block that is directly over the hole that the trun release button used to go through. I can pull it out just a bit and see that. I hooked up a battery, turned the ignition on and pushed the button. No dice, I'll tray having one of the kids push on it while I push the button....maybe the other way around though....
Running is not an option: (IMG:http://home.jam.rr.com/mharrison/New914/MyEngine.JPG) I didn't see any wires going through the engine compartment to the trunk, nor did I see a mechanical cable. I think I'll have to do more investigating before I can sort this out. |
Rockaria |
Feb 17 2005, 08:52 AM
On My 72 back in college with a rear reflector, I ran the wire along the loom in the trunk up the drivers side trough the engine compartment along side the other wires in the loom. I brought it into the cockpit to where the engine compartment release lever and put a button there. So you would have never seen the wire. It looked like it belonged. I grounded the solonoid at the rear trunk and brought 12V to the button from the fuse box on the drivers side, under the carpet to the button. So I only had one wire going back. When I pushed the button it sent 12V down the wire to the trunk and opened.
Just an idea of how one was done. |
Jeffs9146 |
Feb 17 2005, 09:31 AM
Before you drill the reflector you should drill a small hole just below the trunk actuator. Climb under the rear of the car and drill up in the floor of the trunk. Then you can use a coat hanger to pull the actuator down and release the trunk. Prime and paint the hole, then plug it so you can use it later! Jeff Attached image(s) |
mharrison |
Feb 17 2005, 10:48 AM
That's a good idea, but where I'm at right now is not even knowing if it has an accuator and solenoid or the old latch still in place. This may have just been closed (along with the restoration project), when the guy got ready to move.
skline |
Feb 17 2005, 11:03 AM
Well, it has to have the latch or it would not stay closed. The wire through the hole in the reflector will open it whether it has an actuator or not. It hits the release regardless.
Lo-Fi Version | Time is now: 17th May 2024 - 02:36 PM |
