education needed on conversion alternator connections |
type47 |
Apr 21 2015, 04:02 PM
Thinking way ahead while my medical flag restricts me to thinking, not doing. Today I wondered about the alternator connections for a -6 conversion. Here is a pic of the alternator back with the connection points:
You can see the B+ terminals. At about 8 o'clock is a lug with D+ (which you can barely see the "D" part) stamped near it. At about 7 o"clock there is a vertical spade with DF near it and the horizontal spade has D- near it. Here is what I want to connect to: Is it really as simple as connecting the D+, DF, and D- from the alternator to the same on the relay board? And the B+ to the post on the starter which is then connected to the + of the battery? Will the dash alternator warning light then still work? |
worn |
Apr 21 2015, 09:06 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thinking way ahead while my medical flag restricts me to thinking, not doing. Today I wondered about the alternator connections for a -6 conversion. Here is a pic of the alternator back with the connection points: You can see the B+ terminals. At about 8 o'clock is a lug with D+ (which you can barely see the "D" part) stamped near it. At about 7 o"clock there is a vertical spade with DF near it and the horizontal spade has D- near it. Here is what I want to connect to: Is it really as simple as connecting the D+, DF, and D- from the alternator to the same on the relay board? And the B+ to the post on the starter which is then connected to the + of the battery? Will the dash alternator warning light then still work? AFAIK the dash alt light is still required to boot strap the alternator into function. If you have an engine harness to those spots on the alternator, and assuming the relay plate carries the voltage regulator for your alternator, i think it is that simple. If you can call that simple. Good luck with the build and the medicos. I myself just was able to lift a flywheel after a couple months self enforced rest. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:58 AM |
