Bosch wiper blades, No clip for 7mm arms |
914ltd |
Apr 22 2015, 10:25 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Hi all
My last batch of new 13" Bosch blades will not work (properly) on 914 and 911-912 wiper arms. They now only have clips for 9mm arms. Any solutions?? Thanks, Brad |
SirAndy |
Apr 22 2015, 10:40 AM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Weird. I just bought a set from my local Flaps maybe 3 months ago and they had the correct clip.
(IMG:style_emoticons/default/idea.gif) |
r_towle |
Apr 22 2015, 10:45 AM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
just bought a set of bosch and they would not fit....
Seems the metal arm is too wide or something.... hard to see why it wont slide into place, but it wont.... Rich |
green914 |
Apr 22 2015, 01:14 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I bought a set of Bosch wiper blades last month had same problem (IMG:style_emoticons/default/mad.gif) I took the clips out of the old blades, and used them on the new blades.
Tom_T |
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Andy may have a set from the older batch that still fits.
Brad - I'd send the whole order back to Bosch or your distributor that they're improperly made & make Bosch aware that they've screwed up this run, as they may not even know, or maybe it was an ill advised change not thinking of all the vintage/classic cars still using old school blades!? I'll try to remember to ask the Sierra Madre Collection folks sponsoiring at the PCA Z8 SGVR Concours this Sunday if they had the same problem, but PM me on Monday for results, cuz I'll probably forget to get back to you with everything else I've got going on right now. You know .... that "half-zymers" at our age! (IMG:style_emoticons/default/dry.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Larmo63 |
Apr 22 2015, 01:27 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Larmo63 |
Apr 22 2015, 01:29 PM
Or, these, just for the blades……correct 13.25" length
http://www.ebay.com/itm/Porsche-914-1970-1...=item2a4f7ccdf5 |
914ltd |
Apr 22 2015, 08:10 PM
This is the only Bosch arm adapter that even comes close. It is too wide and does not have the crucial lock tab to keep it in place. I have used all my old adapters. Just wish there was a proper part for this.
Good project for 914Rubber.com? Brad Attached image(s) |
somd914 |
Apr 22 2015, 08:24 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Two weeks ago I bought a set of Bosch MicroEdge blades - a bit tight to get on but fit. Maybe my wiper arms aren't original.
andys |
Apr 22 2015, 08:45 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Same experience with the Bosch wipers blades. Returned them for some off-brand which fit fine.....Not to worry, since it doesn't rain is SoCal anyway.
Andys |
rgalla9146 |
Apr 22 2015, 08:47 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Off topic a bit.
Long ago I heard that if a car was fitted with SWF blades it had a SWF wiper motor. Bosch blades ?....Bosch motor. Also it's been years since I saw any blades that didn't extend onto the windshield trim. This is an important topic, that those who want to use their car all year can get new blades. |
Larmo63 |
Apr 22 2015, 08:51 PM
There is a bulletin in the technical manual on this subject. It says to mount the left (driver) wiper on a higher angle as for the blade to miss the windshield trim. There are drawings and a measurement called out. The blades on eBay I mentioned above ARE correct, but they are pricey.
GeorgeRud |
Apr 23 2015, 12:46 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I finally gave up on the Bosch blades as they seem to fall apart too soon. Bought some PIAA silicon blades and they fit fine.
If I have any old Bosch adapters sitting around the garage, I'll send them your way Brad. |
r_towle |
Apr 23 2015, 01:24 PM
I finally gave up on the Bosch blades as they seem to fall apart too soon. Bought some PIAA silicon blades and they fit fine. If I have any old Bosch adapters sitting around the garage, I'll send them your way Brad. better at clearing the water? Float at speed? did you buy them online or in person somewhere? rich |
r_towle |
Apr 25 2015, 07:32 AM
somd914 |
Apr 25 2015, 07:40 AM
I finally gave up on the Bosch blades as they seem to fall apart too soon. Bought some PIAA silicon blades and they fit fine. If I have any old Bosch adapters sitting around the garage, I'll send them your way Brad. My experience with PIAA on my wife's Bimmer has not been good - metal ribs keep popping out of wiper and have also been very noisy. |
GeorgeRud |
Apr 25 2015, 05:27 PM
I bought the PIAA blades on Amazon, but even though they clip onto the wiper arms fine, the clips are a bit too wide. Unless the SKF wiper blades fit correctly, I can't think of many other options that look right on the car.
914_7T3 |
Feb 24 2020, 08:06 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,847 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Resurrecting this thread as my new Bosch wiper blades do not fit the Bosch wiper arms. Can't reuse the old clips as I've mangled them beyond recognition.
Anybody have a solution for what type of blade will work? Came across this listing for SWF and thinking about picking up a set as it specifically references both 7mm & 9mm wide arms. The Bosch arms are 7mm at the end that clips to the blade. SWF- Valeo Wiper Blade Assembly P/N: 96462890102 MY70-76 - 914 Base, 4, 6 Front Left ~ Fits 7 & 9 mm wide wiper arms. Front Right ~ Fits 7 & 9 mm wide wiper arms. https://www.autohausaz.com/porsche-auto-par...eplacement.html |
914ltd |
Feb 25 2020, 10:48 AM
I found these Trico blades. 13" black 7mm arm. The fit perfect and are cheap. I'm not sure how long they last but they are 1/2 the price of the Bosch blades that have 9mm arm fit. Brad Mayeur Attached image(s) |
dr914@autoatlanta.com |
Feb 25 2020, 11:31 AM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we try to use the original SWF or valeo blades no problem with the fit
Lo-Fi Version | Time is now: 5th May 2024 - 01:57 AM |
