| eric9144 |
Feb 25 2020, 12:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,780 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
Interesting timing as I just had to do a 3.5hr drive home in my 914 in the rain and the drivers side wiper was terrible.
These Bosch wipers claim to have 7mm hooks, since I need them anyway based on this past weekends drive, I'll order them and let you guys know. https://smile.amazon.com/Bosch-MicroEdge-40...974+Porsche+914 |
| FlacaProductions |
Feb 25 2020, 03:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
| 914_7T3 |
Feb 25 2020, 05:41 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,890 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
Interesting timing as I just had to do a 3.5hr drive home in my 914 in the rain and the drivers side wiper was terrible. These Bosch wipers claim to have 7mm hooks, since I need them anyway based on this past weekends drive, I'll order them and let you guys know. https://smile.amazon.com/Bosch-MicroEdge-40...974+Porsche+914 @eric9144 Not sure those are going to work as those are the ones I ordered. You can see from the attached pics that the B6 attachment for 7mm is for a straight arm at the tip and not a hook. Regardless, let me know should you achieve success. ![]() ![]() |
| bbrock |
Feb 25 2020, 08:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
These adapters look interesting: https://smile.amazon.com/OTUAYAUTO-Universa...uct_top?ie=UTF8
| Mikey914 |
Feb 25 2020, 08:27 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes we could make a clip that would work if necessary. Just irritating that the wipre manufacturers are changing spec and we get caught in the middle.
| Mark Henry |
Feb 26 2020, 06:40 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Yes we could make a clip that would work if necessary. Just irritating that the wipre manufacturers are changing spec and we get caught in the middle. @Mikey914 How about making refills, just the squeegee for the old bosch wipers? Back in the day I used to just replace the rubber squeegee part. Seeing I have two 914's and a beetle I'd buy almost a dozen sets of refills. |
| Mikey914 |
Feb 26 2020, 11:11 AM
Yes that is fairly easy. The dies cost a bit and I would be running thousands of ft of material as it's not a large extrusion. The question is the profile. I'll put up a thread and see what we get.
Mark |
| 914_7T3 |
Feb 26 2020, 02:31 PM
Add these POS blades to the list with Bosch that do not fit as advertised.
(IMG:style_emoticons/default/headbang.gif) ![]() |
| 914_7T3 |
Feb 26 2020, 02:36 PM
OK @bbrock , I'll give these a go instead of eating the shipping to return the SWF blades. Will post up on the fit once I get them. |
| mxkinn01 |
Feb 26 2020, 03:21 PM
Member ![]() ![]() Group: Members Posts: 271 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region
The last set I bought for my bug was the same. I had to use the old ones. Looks like I’ll be in the same boat when I replace the ones in the 914.
Sorry I’m no help. Mike. |
| bbrock |
Feb 26 2020, 03:58 PM
OK @bbrock , I'll give these a go instead of eating the shipiing to return the SWF blades. Will post up on the fit once I get them. Are the SWF blades 9mm also? I was hoping those would work. Look forward to hearing about the adapters. It would be nice to be able to mount modern blade styles even if they don't look period correct. (IMG:style_emoticons/default/popcorn[1].gif) |
| 914_7T3 |
Feb 26 2020, 04:20 PM
OK @bbrock , I'll give these a go instead of eating the shipiing to return the SWF blades. Will post up on the fit once I get them. Are the SWF blades 9mm also? I was hoping those would work. Look forward to hearing about the adapters. It would be nice to be able to mount modern blade styles even if they don't look period correct. (IMG:style_emoticons/default/popcorn[1].gif) Yup, 9mm for the J Hook and 7mm adapter without the J Hook, same as the Bosch. |
| eric9144 |
Feb 26 2020, 05:31 PM
Porsche Classic is now listing wipers:
http://www.classicshop.porsche.com/pcos-us...6462890102.html I'm curious which ones they are. I noticed the parts selection seems to be expanding which is a good thing but man ~$31 per wiper is steep. (IMG:style_emoticons/default/smoke.gif) |
| 914_7T3 |
Feb 26 2020, 05:53 PM
Porsche Classic is now listing wipers: http://www.classicshop.porsche.com/pcos-us...6462890102.html I'm curious which ones they are. I noticed the parts selection seems to be expanding which is a good thing but man ~$31 per wiper is steep. (IMG:style_emoticons/default/smoke.gif) Same part #96462890102 as the SWF at $4.91 each. I would bet $31 that the Porsche Classic ones don't fit either. (IMG:style_emoticons/default/laugh.gif) |
| Mark Henry |
Feb 29 2020, 04:49 PM
If you have the new bosch blades I may have figured out a work around. I just wrapped a short length of SS cable the around the wiper arm and it takes up the oversize well.
I'll try to post some pic's later. |
| Mikey914 |
Feb 29 2020, 06:13 PM
WOW
Should we really have to modify wiper blades to make them fit??? As the value of the cars go up, it makes our cars look janky! Seems like if I make an adapter that fits the "modern" wipers it would make more sense |
| bbrock |
Feb 29 2020, 09:24 PM
WOW Should we really have to modify wiper blades to make them fit??? As the value of the cars go up, it makes our cars look janky! Seems like if I make an adapter that fits the "modern" wipers it would make more sense (IMG:style_emoticons/default/agree.gif) |
| 914_7T3 |
Feb 29 2020, 11:36 PM
WOW Should we really have to modify wiper blades to make them fit??? As the value of the cars go up, it makes our cars look janky! Seems like if I make an adapter that fits the "modern" wipers it would make more sense (IMG:style_emoticons/default/agree.gif) Still waiting for the adapters to arrive from Amazon. Will post on fitment as soon as they arrive. |
| Mikey914 |
Mar 1 2020, 02:04 AM
Yes if there is a solution that looks stock no need to make them.
Mark |
| eric9144 |
Mar 1 2020, 10:00 AM
Got my new Bosch MicroEdge wipers from amazon yesterday...and... they don't fit the arms at all, had to swap the old clips out to make them work. (IMG:style_emoticons/default/blink.gif)
The clips didn't want to seat on the arms correctly with too much thickness top to bottom, preventing the positive "click" from engaging as well as being just slightly too wide so even if it had clipped in they would have wagged on the arms when in use. That being said, swapping clips is a no brainer, provided you have clips and they're still in good condition. |
Lo-Fi Version | Time is now: 28th November 2025 - 01:21 PM |
