Wiper delay relay add on upgrade mod |
steuspeed |
Apr 23 2015, 06:49 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have the whole column torn apart to install a new ignition switch. What part on the stalk controls to I need to break/modify so that the wiper stalk goes to the delay position like other VW cars? I installed the 99 variable delay relay on my Scirocco and I have another one for the 914. Might as well do it now. Any other tips or links?
(IMG:style_emoticons/default/sawzall-smiley.gif) |
SirAndy |
Apr 23 2015, 11:04 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The tab is on the outer shell and prevents the lever from being moved downward.
Don't have any pics but i recall it was easy to do. (IMG:style_emoticons/default/idea.gif) |
dangrouche |
Apr 23 2015, 11:51 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
here are a couple of threads on the topic of intermittent relay
http://www.914world.com/bbs2/index.php?act...;f=5&t=2094 http://www.914world.com/bbs2/index.php?sho...=111175&hl= |
steuspeed |
Apr 24 2015, 02:27 PM
The tab is on the outer shell and prevents the lever from being moved downward. Don't have any pics but i recall it was easy to do. (IMG:style_emoticons/default/idea.gif) This the tab? Attached thumbnail(s) |
JeffBowlsby |
Apr 24 2015, 05:27 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached image(s) Attached File(s) WiperIntervalRelay_Instructions.doc ( 542.5k ) Number of downloads: 166 |
steuspeed |
Apr 24 2015, 06:46 PM
Where do I buy the relay harness? Do you sell them? |
914Sixer |
Apr 25 2015, 06:34 AM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Jeff B makes and sells harness. The relay can be upwards of to $100. Shop around though. Same relay used on lots of Porsche, VW and Audi. 914 part number is 111.955.531 which is a VW number. You can usually put like 944 in the place of the 111 and get 944.955.531 which is the 944 wiper relay. Used interval relays are on Ebay.
Porschef |
Apr 25 2015, 06:47 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I used the brown/black (IIRC) to power a washer pump. When I pull the stalk towards me, it operates the pump. I do not have an intermittent option. I don't know if a 944 stalk would offer this additional feature, I just try not to drive the car in the rain
jim_hoyland |
Apr 25 2015, 07:01 AM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Check Autohaus,AZ for the relay; IIRC their prices were much lower
If you still need the mountable relay base I have an extra, the wires were cut near the base, but it is still functional. |
larryM |
Apr 25 2015, 07:58 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
wipers ?????????????????? why?
my car don't do rain - - has not done rain since 1992 SCCA driver school - a delay would not have helped . (IMG:style_emoticons/default/yellowsleep[1].gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 01:22 PM |
