914-6 Windshield Wiper Help NEEDED! |
racerbvd |
Apr 25 2015, 11:22 AM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated.
914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4?? Either way, looks like I need a replacement (IMG:style_emoticons/default/mad.gif) TIA |
sixnotfour |
Apr 25 2015, 09:00 PM
914 Wizard Group: Members Posts: 10,431 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
you can make a hybrid linkage..it requires a 4 wiper linkage and a 69-73 911 linkage..it has the correct mount for the motor...But the wiper shafts are too long.. trim the tubes to the 4 length, install 4 linkage and you will have to drill a hole in the center of the stabilizer mount..so it ends up with 3 holes..( 2 which can be welded closed)
oddly enough my 6 bracket is painted silver not zinc plated.. so then install the 6 motor and youre done.... OR find a complete unit..Good Luck Sucks losing valuable pieces..JKH |
sixnotfour |
Apr 25 2015, 09:30 PM
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:02 AM |
