Went for a ride and all of a sudden trans felt like it went to neutral |
westgl |
Apr 25 2015, 03:55 PM
Newbie Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
I went for a ride and all of a sudden no warning, trans felt like it went into neutral, except, trans does not feel like it is shifting into any gears, or between any gears.
It feels more like shift linkage came loose. I tried to shift but did not feel the trans even going through the gears. This is on my 71' 914, Must be something in the linkage came loose, anyone else experience this same situation? I am wondering if i will need to remove a cover on the trans? I was lucky a neighbor saw and offered to tow me back with his truck and on his tow rope. |
rhodyguy |
Apr 26 2015, 08:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
A 71'. Unless the trans has been swapped for a side shift there are no linkage screws to contend with. Presuming the linkage is all functional, I would suspect the rolled pin that couples the 2 levers inside the rear cover. The access cover is on the bottom of the rear of the trans. You will want to drain the gear lube prior to removing the cover. The cover is shown on p.86 fig.5.21 and The pin setup is shown on p.87 fig.5.25 of your Haynes.
Lo-Fi Version | Time is now: 26th May 2024 - 11:58 PM |
