2.0 Oil Leak - Taco Plate area - Advice Please |
mikedsilva |
Apr 27 2015, 01:40 PM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
Being new to these cars, (about 2 months in now) I am slowly getting to know them and work my way through the issues.
One of them, is that there is a pool of oil after the car is left sitting. Mostly, it only leaks after a drive.. when the oil is hot. I pinpointed the leak to the taco plate area.. I don't have a oil temp sender so I am not sure what is under the plate... But there is some sealant around the plate area. The sealant feels very stiff.. almost like JB Weld but I don't think it since it flexes a bit when I press on it.. I found that the leak was a pinhole in the sealant.. Should I be trying to remove all the sealant to see what is under there? Or should I just put a "patch" over it and keep an eye on it? https://www.youtube.com/watch?v=8kOhdj88D_E |
stugray |
Apr 27 2015, 01:54 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
How close are you to your next oil change?
You will need to drain all the oil to try to fix that area. My experience is that you can never "fix" a leak in Silicone by applying new silicone over it. |
Lo-Fi Version | Time is now: 24th May 2024 - 12:55 PM |
