6 conversion - oil tank holes, ..need to position one of the holes |
OllieG |
Apr 27 2015, 02:42 PM
OllieG Group: Members Posts: 212 Joined: 6-July 11 From: UK Member No.: 13,282 Region Association: England |
I can see the light at the end of the tunnel after prepping the engine compartment for the 3.0 6 engine install but I need to cut one more hole for the oil tank. I'm using a DWD tank but it's somewhere buried in storage.
Can anyone help me out with the exact location of the hole marked in the pic?..anyone have a template? Thanks. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1235.photobucket.com-13282-1430167348.1.jpg) |
McMark |
Apr 27 2015, 11:07 PM
That one is a royal pain in the ass. If you value accuracy, my only advice is to drill a small hole, install the tank to see how close you are and keep widening the hole with a carbide burr a little at a time. Each version of the tank is slightly different I've found.
OllieG |
Apr 28 2015, 12:16 AM
Makes sense..thanks Mark. It's also difficult to get the drill into the gap..
914dave |
Apr 28 2015, 04:38 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Ollie
I can help you out on this one. I''m running the same tank and have test installed it. My car (shell) is on the lift, so I can make you a template or pics with measurements. However you'd like. LMK what which you prefer. Dave |
gereed75 |
Apr 28 2015, 07:03 AM
Senior Member Group: Members Posts: 1,246 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Ollie I can help you out on this one. I''m running the same tank and have test installed it. My car (shell) is on the lift, so I can make you a template or pics with measurements. However you'd like. LMK what which you prefer. Dave Dave, Just found your resto pix. Serious work (IMG:style_emoticons/default/pray.gif) I am doing a rolling resto on a six. I used to drill at the Grove. Believe it or not, we had another 914 fanatic in our squadron doing six conversions. Wish I had known you then, would have had more diversions on drill weekends. |
914dave |
Apr 28 2015, 07:59 AM
Ollie I can help you out on this one. I''m running the same tank and have test installed it. My car (shell) is on the lift, so I can make you a template or pics with measurements. However you'd like. LMK what which you prefer. Dave Dave, Just found your resto pix. Serious work (IMG:style_emoticons/default/pray.gif) I am doing a rolling resto on a six. I used to drill at the Grove. Believe it or not, we had another 914 fanatic in our squadron doing six conversions. Wish I had known you then, would have had more diversions on drill weekends. Thanks It actually looks like a car again. Some parts are actually painted. A friend runs the historics there every year. If I ever get out there with him I'll get in touch to check out your project. Dave |
McMark |
Apr 28 2015, 02:38 PM
Makes sense..thanks Mark. It's also difficult to get the drill into the gap.. Yeah, drilling is a PITA there. I use an pneumatic die grinder and carbide bits mostly. (IMG:http://www.914world.com/bbs2/uploads_offsite/442restoration.homestead.com-419-1430253508.1.jpg) |
OllieG |
Apr 29 2015, 02:56 AM
Ollie I can help you out on this one. I''m running the same tank and have test installed it. My car (shell) is on the lift, so I can make you a template or pics with measurements. However you'd like. LMK what which you prefer. Dave Dave, that would be so useful. Pics with measurements would be fine if that's easier for you…but either is fine. Very much appreciated… Mark, yeah got a Carbide Burr like that somewhere under the mess!..I've been meaning to invest in a pneumatic grinder, my electric drill is a bit too full-on for delicate work! Cheers. |
914dave |
Apr 29 2015, 03:35 AM
OllieG |
Apr 29 2015, 04:28 AM
Thanks Dave, well if you can make a template that would be great but really, pics with good measurements would work fine too. I saw on the DWD site, that hole is suggested to be 50mm.
From your pic, you still need to cut a hole in the shelf right? |
914dave |
Apr 30 2015, 06:43 PM
OllieG |
May 3 2015, 01:21 AM
Dave…you rock! Thanks so much. Will post pics once it's done.
Cheers, O. (IMG:style_emoticons/default/beerchug.gif) |
914dave |
May 6 2015, 09:51 AM
Ollie
No problem. BTW I'm a big fan of your artwork. You did Dion's car, it's really well done. When mine is painted and back together, you'll be hearing from me. Anyone who would like a template of the return line hole just get in touch. I can send you a copy. |
Lo-Fi Version | Time is now: 13th May 2024 - 09:30 PM |
