Solid motor/tranny mounts, Solid motor/tranny mounts |
john914somers |
Apr 27 2015, 11:10 PM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
So I am wondering if what tarret engineering says about the solid motor mounts providing more precise shifting is true? Is it noticeable? Worthwhile? Do you have both solid motor mounts and solid tranny mounts on your track car? I have heard that solid motor OR solid tranny mounts are a good thing but not both... But honestly I'm just not sure??? It seems to me that if I have both my 3.6 might rip my little car to shreds, at a minimum it seems like it would rattle every nut and bolt on the car perhaps making the maintenance even higher on an already maintenance intensive ride. Please give me your thoughts/experiences. Hey Chris please chime in. Thanks a ton guys!
ChrisFoley |
Apr 28 2015, 04:30 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
On my 4 cyl race engines I prefer to use a solid mount at the front and a hard rubber mount at the transmission ears.
ThePaintedMan |
Apr 28 2015, 07:15 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Solid rubber as in like the WEVO style trans mounts?
J P Stein |
Apr 28 2015, 07:27 AM
Most engines are not designed to be stressed member.
4 point solid mounts turn it into one. If you want to ignore this info, feel free. |
ChrisFoley |
Apr 28 2015, 07:57 AM
Apr 28 2015, 10:50 AM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have the RJ bulkhead engine mount and use 4 x 911 sport mounts, two in the front for the engine and two on the transmission side.
(IMG:style_emoticons/default/driving.gif) |
campbellcj |
Apr 28 2015, 11:02 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've got 911 sport mounts up front and WEVO on the trans -- works well.
Matt Romanowski |
Apr 28 2015, 09:41 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I've run solid and Wevo. I agree with JP that solid is not the way to go.
Han Solo |
Apr 30 2015, 07:43 PM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
Following this thread.
I've got solid motor mounts and what appears to be poly or nylon transmission mounts. I looked at the WEVO site and didn't see anything like that. These are black material block with a mounting plate. I'll post photos for opinions on if they are too dense or not. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1430446827.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1430446827.2.jpg) |
john914somers |
May 1 2015, 04:30 AM
Following this thread. I've got solid motor mounts and what appears to be poly or nylon transmission mounts. I looked at the WEVO site and didn't see anything like that. These are black material block with a mounting plate. I'll post photos for opinions on if they are too dense or not. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1430446827.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1430446827.2.jpg) So is the black part nylon? Are these made of aluminum? They look pretty heavy??? I've seen some guys take rectangular steel tubing and cut them on angles and make solid motor mounts, I guess it works but it looks pretty clunky and unrefined. For a C note you can buy some new aluminum precision built mounts that look great but they probably aren't any better... Well maybe lighter? |
Matt Romanowski |
May 1 2015, 09:08 AM
Those are solid mounts. It's a piece of Delrin and aluminum.
ChrisFoley |
May 1 2015, 11:49 AM
ChrisFoley |
May 1 2015, 11:51 AM
Han Solo |
May 1 2015, 12:40 PM
Thanks guys. Those are out and some decent OE are in till I get something better.
J P Stein |
May 1 2015, 05:49 PM
WEVO makes some nice motor & trans nounts. Quite firm but allow movement.
I used them for seversl years. Not cheep. |
campbellcj |
May 1 2015, 07:45 PM
I've been happy enough with the WEVO mounts on the 914 that I just got some for the 997 as well. Not installed yet. Not that 914's are cheap anymore, but you should see what they get for the newer 911 stuff.
ThePaintedMan |
May 2 2015, 10:15 AM
I like the WEVO blue trans mounts I have. I'm still not sure that those combined with solid motor mounts is a great idea on a /4. I'd like to hear Racer Chris expound on his setup a little - are you at all worried the torsional stress and vibration weakens the case at all?
stugray |
May 3 2015, 11:03 AM
Following this thread. I've got solid motor mounts and what appears to be poly or nylon transmission mounts. Those Weltmeister hard poly trans mounts suck ass big time! I recommend to anyone who has them - take them out and use something else. Can you explain why? I have them currently with stock front mounts (side shifter). |
Han Solo |
May 11 2015, 08:46 AM
I purchased and installed the WEVO trans mounts. A really nice product. However, at an autocross event yesterday, on my first run, I was unable to get second gear. Apparently the WEVO mount is about 1/2" shorter than OE. Therefore the transmission is slightly raised and that changes the geometry of the shift linkage. My fix was to lengthen the shift rods by pulling them about 1/2" apart at the junction and then tighten. Of course this transmission has not been rebuilt so there's probably other issues beyond that.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1431355572.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1431355572.2.jpg) |
Matt Romanowski |
May 11 2015, 09:52 AM
I didn't have any trouble when I put my Wevo mounts in. They bolted right up and everything worked fine. Maybe they changed?
Lo-Fi Version | Time is now: 7th May 2024 - 03:21 AM |
