SOLD please delete |
ETMracing |
Apr 29 2015, 12:28 PM
Newbie Group: Members Posts: 37 Joined: 22-August 13 From: frederick md Member No.: 16,288 Region Association: MidAtlantic Region |
Smoking deal for someone looking for a easy drop in and go motor. I am only removing because I am switching to a 6.
-this is in my car now and I can test drive or send video clips if shipped- Car is fast and always starts, I have all the receipts. *if you have a 6 we can work a different deal* $3,000 cash or paypal(you pay fee) 1.7 case(ea) with 2.0 pistons -t4 cam .415x278 for carbs -crank -full rebuild 2001 -911 valve adj. lock nuts -Mallory Unilite distributor -Hyfire VI-AL ignition system -Bosch blue coil -Summit racing breather tank-oil- -oil temp sensor -*2011 CFR did pushrod seals. -CB Performance 3.5lbs fuel pump and filter -Dual Weber 44idf recent rebuild. -New Tangerine Racing carb linkage/cables -4-1 Kerry Hunter header to Supertrapp muffler and I can give you my older setup which was heat exchanger minus the heat to a Bursch muffler-removed last month, and I can give you heat exchangers I have had sitting at the shop. *no leaks at all* *recent valve adjust* ** so you get engine, carbs, fuel pump, exhaust, ignition, etc., everything you need to run! 301.213.5101 Chris |
rfinegan |
Apr 29 2015, 03:56 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
What Crank was used.
Was the displacement? estimated shipping to NC 27527 -Robert Smoking deal for someone looking for a easy drop in and go motor. I am only removing because I am switching to a 6. -this is in my car now and I can test drive or send video clips if shipped- Car is fast and always starts, I have all the receipts. *if you have a 6 we can work a different deal* $3,000 cash or paypal(you pay fee) 1.7 case(ea) with 2.0 pistons -t4 cam .415x278 for carbs -crank -full rebuild 2001 -911 valve adj. lock nuts -Mallory Unilite distributor -Hyfire VI-AL ignition system -Bosch blue coil -Summit racing breather tank-oil- -oil temp sensor -*2011 CFR did pushrod seals. -CB Performance 3.5lbs fuel pump and filter -Dual Weber 44idf recent rebuild. -New Tangerine Racing carb linkage/cables -4-1 Kerry Hunter header to Supertrapp muffler and I can give you my older setup which was heat exchanger minus the heat to a Bursch muffler-removed last month, and I can give you heat exchangers I have had sitting at the shop. *no leaks at all* *recent valve adjust* ** so you get engine, carbs, fuel pump, exhaust, ignition, etc., everything you need to run! 301.213.5101 Chris |
ETMracing |
Apr 29 2015, 04:44 PM
2.0 crank was used in the 1.7 case, and 2.0 94mm pistons/cylinders. I would deliver for $200.00 since that way I can insure a quality shipment.
What Crank was used. Was the displacement? estimated shipping to NC 27527 -Robert Smoking deal for someone looking for a easy drop in and go motor. I am only removing because I am switching to a 6. -this is in my car now and I can test drive or send video clips if shipped- Car is fast and always starts, I have all the receipts. *if you have a 6 we can work a different deal* $3,000 cash or paypal(you pay fee) 1.7 case(ea) with 2.0 pistons -t4 cam .415x278 for carbs -crank -full rebuild 2001 -911 valve adj. lock nuts -Mallory Unilite distributor -Hyfire VI-AL ignition system -Bosch blue coil -Summit racing breather tank-oil- -oil temp sensor -*2011 CFR did pushrod seals. -CB Performance 3.5lbs fuel pump and filter -Dual Weber 44idf recent rebuild. -New Tangerine Racing carb linkage/cables -4-1 Kerry Hunter header to Supertrapp muffler and I can give you my older setup which was heat exchanger minus the heat to a Bursch muffler-removed last month, and I can give you heat exchangers I have had sitting at the shop. *no leaks at all* *recent valve adjust* ** so you get engine, carbs, fuel pump, exhaust, ignition, etc., everything you need to run! 301.213.5101 Chris |
wndsnd |
Apr 29 2015, 06:32 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Smoking Deal...
ETMracing |
Apr 30 2015, 07:42 PM
Replied to must pms, yes I can do a discount if certain items are unwanted, carbs/headers/ignition... and I have videos being uploaded of a start up and a Drivers Ed. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-16288-1430444526.1.jpg)
billh1963 |
May 1 2015, 08:49 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
How many miles on the engine? Rebuild was in 2001?
rfinegan |
May 4 2015, 01:36 PM
PM sent
-Robert |
rfinegan |
May 5 2015, 04:57 AM
Thanks For the video, Lets work out a plan when you can pull the motor and Im thinking I will pick up.
I will take it! -Robert |
Lo-Fi Version | Time is now: 15th May 2024 - 06:40 AM |
